If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Cheers for that info bronk. There arent any yellow ticks, ans i have been able to change to mono which was good..only after a re-install. The only other drama now is static. I have read around other sites that people are having dramas too. Mine isnt happening other than when i am playing back. Funnily enough, the **** worked fine yesterday, even after a re-install. Any suggestions on static anyone? Have elimated the leads, one by one, and its the sound card, in some setting...just dont frigging know how to stop it. And no, its not radio either.
