You can go to radio shack or other store and buy a plug adapter for your brand of radio that will match both the radio and the cars wiring so all you have to do is disconnect the factory radio and plug in the adapter to the radio and the original car wiring plug and your set to go without figuring out which wires to connect to and removing the possibility of causing wiring problems with the car
For
more help on car radio problems, I suggest you to go through these
troubleshooting links, these will help you: -----
Click
the link below: ---
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These
details will help you thanks.
For
Click
the link below: ---
These details will help you thanks.
To reprogram the
radio there is 4 digit code. That code has to be inserted, once these code is inserted,
your car radio will get into its actual setting where you can set/select your
radio setting.
Many
a time's radio asks for the code after car battery is disconnected.
On
some cases to retrieve the code its mentioned in manual or else car
dealer is other option to get car radio code.
For
Click
the link below: ---
Many
On
For
Click
the link below: ---
To reprogram the
radio setting.
Many
On
For
Click
the link below: ---
Cigarette
lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe
mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on
1990 Toyota Celica?
Radio Stereo Wiring Diagram
for 1991 Chevy 1500?
How to remove radio on
Acura Car models?
Where is Radio Fuse located
on 2007 Dodge charger?
How to reset Radio code
after car battery is died?
Can car radio code block
Passkey anti theft system ?
After Market Stereo wiring
for 1999 Chevrolet Silverado 1500?
Chevy car radio doesn't
allow to switch to the XM Band to get the radio ID?
No power to radio on 2005 Toyota Scion Xb?
Lexus rx330 Radio has power but no sound?
Radio goes ON and OFF while driving?
Lincoln Town Car Radio stereo
wiring?
Radio wiring diagram for 1997 Lincoln Town Car?
How to remove cd player from dash on 2003
Lincoln Aviator
Cigarette
1990 Toyota Celica?
Acura Car models?
wiring?
Lincoln Aviator
---------Headlight wiring diagram for 1997 Lincoln Town Car?http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
----------This will help.Thanks.
