Contributor
- Posted on Mar 02, 2011
Re: We just put new ink in and it prints out fuzzy . how...
Every time you replace ink you need to do an alignment. To do this follow these simple steps:
- Press the Ink or Ink Management key on the control panel.
- Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
- Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
- Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
- By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
- Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
- Press Stop/Exit.
