Televison & Video Logo
A
Anonymous Posted on Mar 02, 2011
Everything working except I can't get digital channels. It comes up with no signal. But all digital SBS channels are working fine. How could that be.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
1691
Points
22
Is it saying no signal or one moment please? No signal is a dead give away; there isn't any. One moment please can be several things. Low signal or cable box isn't active. How do you have your connection from your cable box set up as? Coaxial cable, RCA, HDMI, or component? Also, make sure whatever connection you're using, connect from you cable box out into your TV's in (type of cable you're using) Make sure you're on the correct input. For example. RCA may be video 1 or 2 depending on where you plugged it in. Hdmi -> may be HDMI 1 or 2. Coaxial may be channel 3 or 4 on your tv set. Hope this helps.
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
How do i tune my digital tv again for some reason sbs channels and some other channels have disappeared from my set
Find the factory default setting on the menu. Select it and then retune your set. That should restore all the channels. By the way make certain the aerial and all leads are good. And bear in mind you need a good quality aerial for digital signals, such as the one below.
No sbs didital channel coming up
You first need to ensure if you have any SBS digital signals in your area. I take it that you are in Australia. Go to this website for more info. If this is not what you are looking for let me know.
http://www20.sbs.com.au/transmissions/
http://www20.sbs.com.au/transmissions/index.php?pid=1
If you have received SBS signals before and now you aren't there may be a setting on your tv that changed the component input from SBS to something else. Check to make sure the component inputs that the signal is coming in on is selected on the tv. I sure hope this helps you. If not, give me a little more info and maybe I can help a little more.
1helpful
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
9helpful
2answers
I just purchased the RCA model L32HD31R. Everything works fine except that I can't remove the analog channels from the list. I get my signal OTA so no cable or sat issues. I go into the List Menu and they...
I had the same problem and finally sloved it. You have to leave the input channels ( Vid1, Vid2, SVid, Cmpt, HDMI, etc ) in the In Channel List. So push the INPUT button, go to VID1, press Menu, go down to List & Labels then check In Channel list. Do this for all the inputs and then run your Channel search again. I hope this works for you. It did for me.
2answers
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
2answers
Poor tv reception on my new lcd screen
Hi, sounds like the antenna. Maybe get an Aerial company to check it out for you as you might not be picking up a strong enough signal.
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
