If you wish to get some details; visit the site linked here. Pull up older posts.
SOURCE: 40" Sony BRAVIA KDL-40S2010 LCD HD TV
what kind of cables are you using? Make sure you get the HDMI cables. Also, the S and V Sony series only have a refresh rate of 60Hz, which means that when you get fast action scenes or when people are moving, you will see a very noticeable blur. There really is nothing you can do about this. I had a V series and immediately returned for a W series, which has a refresh rate of 120 Hz. Sometimes, you can still see the pixelation, especially if the TV can't handle the response time, but it is definitely less noticeable than the other series.
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
the error code is triggered by the inverter fuses, which blow when the inverter fails
SOURCE: Sony Bravia TV, stays on standby with a flashing
power supply/ in uk look up ohm supplies to repair it
