If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they
refer to.
This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps.
This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps
You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps
This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps
You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep
This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep
You have a system memory problem
Five short beeps
You are facing a problem with your CPU
Long constant beeps
It’s a system memory problem
Short constant and high-pitched beeps
The temperature of your CPU is too high
