Question about Dremel Variable - Speed Multipro Rotary Tool 395
Plug it in - turn on switch - nothing happens
  • 12,061 Answers
OK there's not much to these first check, the power plug, check cable, if you can, open it up and see if there is power to the On/Off switch, if there is check the switch, if they are all good but still no go, then most likely culprit is the speed controller, you will need to replace it.
Posted on Mar 02, 2011
SOURCE:
I have a 95 honda accord dx. When i put the key in and turn it nothing happens. All my dash lights come on but nothing trys trys turning over or anything. I was told by a handful of mechanics and people at...
Only thing it could have been in the first place is the wire from the switch to the starter is disconnected from the starter. Even a new switch won't fix that. Just get under the car and plug the wire back onto the spade connector.
Aug 26, 2014 | 1995 Honda Accord
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
When I plug in my pro form 370e crosswalk it doesn't turn on nothing happens
1) test the outlet wall, reset the c.breaker from your house, or tes the fuse if are blown.
if the problem NOT result and is o.k the c.breaker
2) test the power cord, for open
3) Eliminate any extension cord
4) test the main switch for open
5) reset the switch attached to the main switch.
6) tight any wires loose
7) reset the c. breaker or replace the fuse blown see the block.
God bless you
Jul 02, 2012 | Exercise & Fitness
When I plug it into the usb port nothing happens, it won't turn on, is there some kind of switch I need to turn it on?
iNSTALL PRINTER DRIVER.
PLUG IN THE PRINTER VIA USB
TURN "ON" PRINTER
IF NOT RECOGNISING THEN PROBLEM WITH USB CABLE OR USB PORT OR PRINTER PORT.
Jan 13, 2011 | Office Equipment & Supplies
I have a Lincoln 120v wire feed welder, model 140, and while welding, the gun cam unplugged and it arced a little on the plug end, and now, the fan runs, but nothing else will happen, it has been two hours...
Check your switch terminals, if they are connected and everything looks good, then unplug the terminal and bridge the connector (bypass it) if it start turning your drive rolls then your switch it's damaged, if nothing happens then you burned the pc board.
Dec 08, 2010 | Welding Tools
NOTHING HAVPPES WHENI PLUG IT IN AND TURN SWITCH
Hello Sir,
Make sure that the fuse or the relay of the supply unit is intact and in working condition. If not that there is some trouble in the power supply unit.
Regards.
Nov 15, 2009 | Magic Chef MCWC16MCG Wine Cooler
My xc356 has simply stopped working. Nothing happens when I turn it on.
Generic comments follow:
Nothing happens when you turn it on ... no indicator light, nothing ... do you have power to the device? is there power in the wall where you plug it in?
I think I would remove the cover and start looking for a fuse very near where the place where the cord comes in.
Unless you have technical abilities beyond the norm ... I wouldn't look much further. On the other hand, if you have a volt ohm meter, you could check for power at the switch and you could check the contacts of that switch. Is there a door or cover that has an interlock on it that may be ajar?
It would make sense that if you have power to the switch yet nothing happens when you turn it on ... there is a bad switch. If there is power on the other side of the switch when you turn it on ... start looking for another switch ... like a safety or interlock. I think there is a capacitor in that machine ... if you have power inside and nothing starts, the capacitor could be faulty. Dont fool with it unless you know what you are doing. It sill probably be a big silver can looking thing or it will be about the size of a TP tube roll and have a couple wires coming out of it.
Let me know what happens.
A
Sep 21, 2009 | Xerox Office Equipment & Supplies
Husqvarna YTH Lawn Mower will not start
try wiggling the plug while turning the key.
you may have loose terminals inside the plug
May 05, 2009 | Husqvarna Garden
Heat/AC doesnt work
is the switch on dash in one piece as on these cars the bottom of the switch breaks ,you push switch to turn on a/c and turn it for the fan left is re circulate right is fan with fresh air in as well
Jan 08, 2009 | 1999 Ford Escort
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
76 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen II
Van Allen II
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
