Olympus Stylus 760 Digital Camera Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Two of the outer screws fell out. Where can I buy spares?
Anonymous
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Mar 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
22744
Points
245
Http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Call 1-800-622-6372, Mon-Friday 8:30AM-7PM Eastern.
Olympus may be able to ship you the screws.
Hi, When I opened the oven door the outer glass panel fell off. It looks like the vent bar will need to be replaced. I am not sure if that is the only piece that will need to be replaced.
contact the service agent for that make and model of the oven
if individual parts are available then they will have them
other than that find an appliance repair shop as they may have a spare door off a machine that cannot be repaired
Sep 25, 2015 • Ovens
I am replacing the outer door panel on a Bosch Dishwasher. 2 Plastic brackets fells out of the inside of the door when I removed the inner stainless panel. How do they fit back inside?
DOH!! Trial and error. If you cant get access to an exploded parts diagram, I would suggest look closely at the bits that fell out and see if you can "nut out" where they came from. If they just fell out , I would imagine that they just "sit somewhere" If there are screw holes in them, when you undid one or more of the door screws, they must have come undone as well. Often, there are screws that don't need to be undone when stripping doors, as they hold something else in place. Look closely, you should find where they come from. Good luck.
I have an Alessi 9098 stainless steel pepper mill given as a wedding gift. It fell from a table and the blue fin broke. Is it possible to buy the blue fin? If so, how would I go about it?
Yes! you can get the part here:
http://www.connox.com/categories/spare-parts/replacements-alessi/spare-parts-alessi-pepper-grinder.html
Its 6 euro
2answers
My heater makes a real loud "air" sound,then the
On mine the rivets that hold the outer ring to the inner ring fell apart, allowing space for additional air into the air/gas mixture. Replaced all the rivets with screws and lock nuts. Had to remove the guards for better access. Did the trick for me. When you handle the outer ring, you may find it has sharp edges, handle carefully. Hope your luck is as good as mine was.
1helpful
Small (front) baffle in tube of Maytag Nautilus
i cant imagine why you would have too,just drill the screws till the break off andlet them fall w/in theinnner and outer tub.then get the screws out of the catch all at water pump,they might even pass through the drain hose....if you seperate the tubs,youll need time and a new seal between the tubs
The volume control knob fell off can i buy a new one model htr 5860 yamaha
Sometimes volume controls are held on by an Allen type screw, which can become loose, allowing it to fall off. You should see a hole in the knob if it is. You might need a long thin Allen Key to get it back on.
Otherwise have checked my spares guide (though it's a few years old) and it seems Yamaha might only do their own spares.
The glass on the inside of the oven door has fell away while i was cleaning it,can not see any way of putting it back on,is it glued on?
that is your heat safety glass if the outer pane is still there,you will need to dismantle the oven door and reseat it in its frame in the oven door,the screws are on top of door and on inside when door is down,im sure you'll find it..and dont run self clean w/o safety glass in place,outer glass wont take the extreme heat of self clean feature
Jul 24, 2009 • Ovens
Washer
If at first you don't succeed......
If you still don't succeed....... Call "the man" !
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
