Texas Instruments TI-83 Plus Calculator Logo
A
Anonymous Posted on Mar 02, 2011
How do you calculate the cubed root of a number or 5th root of a number?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Mar 02, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442635
Points
622693
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
Arvin RePoL
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 22, 2015
Arvin RePoL
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2611
Points
10
In excel it's very easy, To find the cube root or any root of a number just raise the number to the desired root.
Example: cube root of 10
in excel just type:
= 10^(1/3)
5th root of 5
just type:
= 10^(1/5)
3 Related Answers
  • 102366 Answers
  • Posted on May 27, 2010
SOURCE: Finding a cube root on calculator
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
Anonymous
  • 3 Answers
  • Posted on May 17, 2008
SOURCE: Cube roots
You use the y^x (y to the x) key along with the 2nd function key. That does the opposite operation.
So, let's pick something we know the answer to as an example. How about the cube root of 8? We know 8 = 2 X 2 X 2, so the cube root of 8 will be 2.
Here's how:
8 2nd y^x 3 =
The display will show 2.
The three is the root you want. You can put in any number, with 2 being the square root, 3 the cube root, etc.
Anonymous
  • 6 Answers
  • Posted on Jan 26, 2009
SOURCE: to work out the cube root of a number
I am guessing, but, find the key that has a 3 to the left of the root symbol, looks like a check mark. Push it, then the number you want to take a cube root of, then enter.
8helpful
Can I use the ti-30xa to find cube root, 4th roots, and 5th roots?
Use the x-root function, which is the 2nd function of the y^x key located just above the divide key. For example, to find the cube root of 8, press 8 2nd x-root 3 =
6helpful
6helpful
What are the steps to find the cube root of a number using the TI-86 calculator?
Use the root function in the MATH MISC menu.
To find the 5th root of 32: enter 5 then the root function and then 32 and then ENTER to get 2.
Cube root of a number
push 3
then push 2nd
then push the carot symbol ^ some calculators have this as y^x
then enter your number
If that fails use the calculator program in your computer and change its view to scientific. This has cube roots
6helpful
Is it possible to calculate cube root or higher with BA ii plus?
To extract the roots of orders higher than 2, you can use the universal power key labeled as [Y to x]. if the exponent is an integer 3, 4, 5, 6 etc.
it gives the cube the 4th power, 5th, 6th, etc.
If the exponent is 1/3, 1/4, 1/5, 1/6 you calculate the cubic root, the 4th root and so on.
When you use it to calculate the roots, the radicand (the number the root of which you are calculating) must be positive, otherwise you may get the result as a complex number.
The syntax of the command is value [Y to x] (1/ order of root)
Ex: cube root of 27 is entered as 27 [Y to x] (1/3)
Cube how do I cube where is the function
x-th root of a number equals the number to the power of (1/x) where x is a natural number.
square root = to the power of (1/2)
cubic root = to the power of (1/3)
3helpful
3answers
How to find cubed root on a TI-89 calculator
To find the cubed root (or any root) of a number, use the root() function.
If you want the cubed root of 125, you would type:
root(125,3)
1helpful
Cube root
http://answers.yahoo.com/question/index?qid=20071129202945AAOndt7
You can multiply a number by 1/3rd to get the cube root or
Under the MATH button, the fourth option down will give you cube root. Any n root beyond that will require the x^(1/n) method.
35helpful
3answers
Entering a cubed root into a ti-83 plus
You can enter any root by typing the number, then hitting MATH and 5, which brings up the root symbol with the x in front of it: x√. So the fifth-root would be 5 -> MATH -> 5 and then whatever number you want to get the fifth-root for: 5x√10 for example. As someone else had mentioned, you can also raise it to a rational power: 3^(1/3) which would be the same as the cubed root of 3, but you could also type: 3 -> MATH -> 5 -> 3 and get the same answer, but looking like this in your calculator: 3x√3. The option for 4 actually is a predefined cubed-root, and the one for option 5 there is the root symbol that can be used with any number before it to get any root you want. There are no parenthesis as you get when using the predefined square-root and cubed-root functions, though, so you may want to type them in yourself if entering a long string of operations in the calculator at one time to make sure the calculator doesn't include numbers under the root that you don't want it to. But I guess it depends on preference in terms of what method you choose between the rational exponents or the root symbol (and most would go with whichever seems easiest and quickest to enter), but you asked specifically how to get the cubed-root on the TI-83 Plus, so there's my best attempt at answering your question.
15helpful
Cube roots
Here's how:
8 2nd y^x 3 =
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
