Question about Nintendo Wii Fit - Balance Board + Game Console
Light going off and on - Nintendo Wii Fit - Balance Board + Game Console
    New Friend:
  • 5 Answers
Put in a Wii Fit compatible game. Start the game up.
Once you bypass the wrist strap safety message open up the SD card slot on the front of the Wii and remove the battery cover on the Wii Fit Balance Board.
Press and release the sync button. The blue light will start blinking. Then press and release the red sync button on the Wii console.
If this does not fix the problem make sure the battery level for the balance board is not low.
Change the batteries anyway just incase.
If that still does not fix the problem, make sure the game you are using is Wii Fit compatible.
Posted on Mar 02, 2011
SOURCE:
No low beam head lights on 1999buick regal
Do you know how to do basic automotive electrical testing ?
Headlamps Inoperative - Low Beams
Disconnect the headlamp switch.
Turn the headlamp dimmer switch to the LOW position.
Using a test light, frontprobe between the headlamp switch harness connector terminal D to ground.
Does the test light illuminate? YES - NO ?
Using a test light, probe between the headlamp switch harness connector terminal D to ground.
YES - Go to Step 3
NO - Go to Step 4
Replace the headlamp switch. Refer to Headlamp Switch Replacement .
Has the repair been made?
Go to Headlight System Check
Repair a poor connection or an open in circuit 1750 between the headlamp switch and the harness connector terminal A and G201.
5
Reconnect the headlamp switch.
Using a test light, backprobe between connector C201 terminal A3 and ground.
Go to Step 6
Go to Step 7
6
Repair a poor connection or an open in circuit 10 between the harness connector C201 terminal A3 and S221.
7
Using a test light, backprobe between connector C201 terminal A2 and ground.
Go to Step 8
Go to Step 9
8
Replace the headlamp dimmer switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle .
9
Using a test light, backprobe between the underhood accessory wiring junction block harness connector C2 terminal F10 to ground.
Go to Step 11
Go to Step 10
10
Replace the underhood accessory wiring junction block. Refer to Accessory Wiring Junction Block Replacement .
11
Repair a poor connection or an open in circuit 1201 between the underhood accessory wiring junction block harness connector C2 terminal F10 and connector C201 terminal A2.
Go to Headlight
Feb 18, 2017 | 1999 Buick Regal
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
How do I reset the consumables counter on myBrother HL-2035 printer printer
1.) Turn the printer off.
2.) Hold the 'go' button while turning the printer on. All panel lights should be on.
3.) Release the 'go' button once all lights are off.
4. )Press the 'go' button 2 times.
5.) Pause.
6.) Press the 'go' button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your "low toner" light should be fixed.
Jun 16, 2013 | Brother Hl-2035 Drum
2006 monte carlo lt tail lights not working
does the tail lights go on when you put on the head lights? with the head lights off and the brake pedal pressed does the light go on? if the light go on with head lights and not with the brake pedal it is a your brake light switch. it is located on the brake pedal
Feb 09, 2013 | 1995 Mitsubishi Galant
I have a 96 infiniti G20, I am having dash light problems and nocticed when the dash lights go out so do the tail lights so where would be a go place to start looking not sure here i ahve no manual or...
The dash light are on the same circuit as the tail lights as a safety feature. You know when the tail light are out because the dash lights go out when they do. Check the fuse box. If the lights are going out and coming back on the fuse or wiring to that fuse may be loose.
Dec 20, 2010 | Infiniti G35 Cars & Trucks
Can this light be set to only come on from dusk to dawn? This was installed by an electrician and he failed to leave the written instructions.
Yes,this light system is a motion sensor security light.Just turn the light switch on.When the sun goes completely down,somebodies or anamials go by the sensor covering area the light will go on.The sun rise the light will go off,will not go on.
Nov 24, 2010 | Heath Zenith All Metal Motion Sensor Light...
How do I reset the drum unit on this machine
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
Aug 11, 2010 | Brother HL-2040 Laser Printer
Laserjet 2015n powers up for 2-3 seconds - but no lights come on - and then it powers down.
Please perform the following.
Super NVRAM initialization Turn off the printer.
  1. Press and hold the Go button.
  2. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process, the Attention , Ready , Go lights turn on. Then the Attention and Ready lights turn off, leaving only the Go light illuminated.
  3. Release the Go button. The Go , Ready and Attention lights turn on.
  4. Press and hold the Go button. All lights turn off. During the next three seconds, the Go , Ready and Attention lights turn on in that order, one per second.
  5. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
Sep 19, 2008 | HP LaserJet P2015dn Printer
Toner light on
Open the front cover and leave open while completing the following steps: Turn the printer off. Hold the 'go' button while turning the printer on. All panel lights should be on. Release the 'go' button. Press the 'go' button 2 times. Pause. Press the 'go' button 5 times. The toner light should be off. The paper light should be on. Close cover. The ready light should be the only light on.
Apr 18, 2007 | Brother HL-2040 Laser Printer
Nintendo Wii Fit - Balance Board + Game Console Logo
203 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
