Door ice lever/dispenser just stopped working , Icemaker is still working fine and door water comes out fine, pulled out ice bin, manually turned the armimiture that turns the cylinder in the ice bin and that seems to turn fine (not frozen up) Its been working great for 2 years and all of a sudden tonight...nothing!
Your question is worded in a way that I might not be interpreting it correctly. I am guessing that it is making ice but not dispensing,or going into your glass when you push the lever, right?
So when you push the ice dispenser lever do you hear a "click" like you do when you push the water lever? Push them slowly and listen.
If no "click" is heard then it is most likely the bracket that holds the dispenser switches. It is made of plastic and very prone to breaking over time especially if children are using it. Part# is WP2180226 and be aware that this is under live voltage so if you are not mechanical then do not attempt yourself and please call a pro to fix.
If you hear a "click" then can you hear the motor turning inside? If yes then it could be something as simple as a block of ice stuck in the bucket preventing the ice from coming out. The owners manual recommends to dump the ice to avoid this roughly every two weeks but most people never do.
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out. look for an adjustment behind the plastic
endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Most automatic ice makers have a lever (looks like a piece of wire) that is prevented from being in the down position when the bin is full. This stops the ice maker from producing ice when not needed. The lever can also be lifted manually to a locked up position which turns the ice maker off as well. If the lever is in the up position, simply press down on it, it should release and return to the down position. Once down, the ice maker will begin producing ice again (the unit will have to complete its cycle before you see any ice, normally a couple hours or less). Hope this helps.
Please take the time to give this solution a fix ya rating.
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
On advice from the tech I removed acess door. It was covered by frozen moisture. I removed the motor it was full of water. I verified 120 volts at plug to motor from control by depressing the door switch and ice dispenser lever at same time. The motor ohms out but because of amount of water removed from it I am going to replace it and see what happens.
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
