Hi, Turn off the camera. Remove the battery pack. Press and hold the power button for 30 seconds. Allow the camera to remain without power for 60 seconds. Reinsert the battery pack. Turn on the camera.
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
