If you want good results you must clean the print heads manually. Follow the procedure below:-
Apply a folded tissue paper to the ink nuzzle and press
firmly. If the tissue comes off well blotted with ink it means you still have a
good amount of ink in it and the nozzle is not blocked. If not blotted or scantily
blotted, it means ink is really low or nozzle is blocked. To be very sure of
this, place nuzzle in a plate/saucer with a bit water so that the nozzle is
soaked. Leave for about 10 minutes. Then apply the tissue again. If still not
well blotted it means ink is really low or empty. If new you should return it
for a replacement. In the case of blocked nozzles, the procedure may be
repeated over to get results. If the yellow continues to print green, you must reinstall or format your system. Usually wrong colour registration is caused by a malfunction in the system not the printer. If it is a printer issue it usually returns gradually to the right colour after a number of print outs. Good luck and God bless!
