This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Hello, my problem will soon be resolved by employing a professional smeg electrician who said I needed a new thermostat. Thank you for reading but I no longer need 'fixya' assistance this time around.
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Contact these guys, they import Smeg products into the country and have manuals available online also.
APPLICO GROUP LTD: Whiteware Importers
120 Captain Springs Rd Box 92900 Onehunga Auck Ph (09)574-1050 Fax (09)574-1051 email: [email protected]
http://www.applico.co.nz/
