Frigidaire FGB24S5A Gas Single Oven Logo
Posted on Jul 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire gas oven not working
I have a frigidaire gas oven with an electronic ignitor. The power went off and when it came back on the oven wasnt working
Syzys
Level 2:
Sergeant:
  • Expert 361 Answers
  • Posted on Dec 06, 2014
Syzys
Expert
Level 2:
Sergeant:
Answers
361
Questions
0
Helped
204191
Points
853
It sounds like you either had a short circuit or a fuse blowout. You can replace the fuse yourself with a new one, it's fairly simple, but you still might want to check out the manual for your device thoroughly:
Frigidaire gas oven manual
Anonymous
Level 2:
  • Expert 75 Answers
  • Posted on Jul 29, 2008
Anonymous
Expert
Level 2:
Answers
75
Questions
0
Helped
29224
Points
154
When the power returned there would have been a high voltage which would have blown out the fuse cange the fuse and on it
Frigidaire gas oven not heating. The broiler and burners work but the lower burner will not ignite. I replaced the igniter however that did not fix the problem. In fact, the new igniter does not glow. I...
Check for volts to the new ignitor. The ignitor draws current which opens the gas valve. If it is not glowing it is not drawing power. Test the ignitor,disconnected, with an ohm meter, it should be under 200 ohms.
Dec 28, 2013 • Ovens
STOVE WORKS BUT OVEN WILL NOT HEAT UP - GAS OVEN
There are 2 high likelihoods as to what your problem may be. When you turn your oven on, does the ignitor begin to glow within 15 to 30 seconds? If it doesn't, there is no power going to the ignitor and the control mechanism is going to need to be replaced. If you have a manual dial thermostat control, you can order this on-line at parstdirect.com. If you control is electronic, you will be required to have an appliance technician come out in order to send the old controller in to be rebuilt.
If your ignitor is glowing when you turn on your oven, but it has a very dull orange glow, you have a bad ignitor and it needs to be replaced. This is the most common problem with older gas ovens. The ignitors just burn out after time and do not draw the amperage needed to open the safety valve.
Replacing the ignitor is a fairly easy procedure. Replacing a dial thermostat control can be a little rough due to rerouting the thermocoupler back through the oven body. Unfortunately, the electronic style oven controls can only be sent in for rebuilding and the company that you use will need to be able to handle "Retforrepr Rebuilds".
Unable to get my frigidaire gas stove top oven to ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
I have a Frigidaire model FGFL87DCE gas range and the oven will not work. It doesn't light and the gas doesn't come on
the first thing to check is the ignitor.turn the oven on and look to see if the ignitor is getting hot if it not you will need to check the power to the ignitor.if there is power to it then you may neeed to replace the ignitor.
If the ignitir is not drawing enough current then it will not open the gas safety valve
1helpful
I have a 30" Frigidaire
the most common cause is a bad ignitor. if the igntor is not drawing enough current it will not open the gas safety valve. you should be able to open the bottom drawer and look at the ignitor is working how ever it should be bright white in the middle,if not replace it.
1helpful
Frigidaire oven will not ignite
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
3helpful
3helpful
I need to change my oven ignitor and I need a diagram to show where it is located. I have a Frigidaire model FGF353BADB. Free standing gas stove/oven.
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Fiigidaire gas oven trips power when I turn oven on
disconnect the wires going to the oven ignitor,turn the unit on see if its trips.if so the ignitor is shorted if not then disconnect the wires that go to the coil of the gas valve and do the same.i think either one of these is your problem.also if theres a fan in the oven do the same.
3helpful
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
