Expert
- Posted on Mar 02, 2011
Re: How do you release the brewing head after removing...
- release filter bolt
- remove filter
- release& remove the alien
bolts in filter holder
- push it from side with screw deliver,
you don't have nothing attached, it will come down
- once filter holder is out you
clean it good specially the 4 holes in sides
- While removing the old seal you
might need to be bit rough, to cut the seal if it is too hard and non
elastic at all anymore.
- clean it good and brush the
place of seal
- take the new seal with
numbers(mark on the seal) up and put it in the place so that numbers are
going up to group
- push it with hand a bit
- get the portafilter without
filter
- and put it in left teeth
>>> roll a bit like when you put it in place
- do the same with left one
- repeat action in both
teeth and with filter
- Control the seal, if it
fits good in place.
- Assemble everything back and
drink one espresso as an reward for work.
Testimonial: "Thanks very much for taking the time to reply. I managed to remove the seal using two very sharp screws and a pliers. Worked a treat. Thxs again. Phil"
