Technics RS-TR272 Single Cassette Deck Logo
Anonymous Posted on Mar 01, 2011
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as soon as I do this ... the deck one stops.
T-Comtech Repairs
Level 2:
Guru:
  • Expert 417 Answers
  • Posted on Mar 01, 2011
T-Comtech Repairs
Expert
Level 2:
Guru:
Answers
417
Questions
Helped
110856
Points
317
For a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
  • patbest Apr 13, 2011
    i put the tapes in and pressed sync rec and nothing happened - i pressed rec and play and nothing happened
Dcr-trv280 ntsc cassette will not load
Not certain of the type of model this is, but some tapes have anti record tabs. Or the tab has broken off preventing recording. You can put a piece of sticky tape over the broken tab to allow recording again.
4answers
How to record a cassete tape
Typically, to record on a cassette tape you must press BOTH "Record and Play" buttons at the same time and the tape recorder will begin to record.
What is the reason the tape won't play on sa-ak95
It may be the tape(s) themselves. Pre-recorded cassette tapes are usually no problem for most players, but many user-recorded tapes were of the C90 or C120 variety. These cassettes use much thinner tape in order to get the recording time. This can cause the tape, after many starts and stops and partial fast-forwards and rewinds to get tight on the reels. This will cause the tape sensor to think that the tape is at the end of the reel when it is not. Sometimes rewinding from end-to-end will help, but not always,
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
2answers
How do you record onto a tape from a CD?
I couldn't find the exact manual but the XL-HP505 may be close enough...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sharp-XL-HP505-manual/id/285dj790/t/2/
1helpful
4answers
I CANT RECORD CASSETTES ONTO A FLASH DRIVE
You can't. Cassettes are analog and the USB only recognizes MP3. The USB will only record off a normal CD or a CD with MP3s on it. It won't record other formats. The unit only allows to record from CD to cassette or from CD to USB. There are some cassette decks that will convert to MP3. Just do a search for "cassette to MP3 converter"
Says "protected" and buzzes when new tape is put
Hello make sure that your cassette don't have a broken tab on bottom of tape if tabs are Ok send your unit to adjust the procttioon record Switch you can send your unit,Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
4helpful
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
1helpful
2answers
Dubbling cassette tapes
After looking @ the owner's manual online, I can see why you're confused. Man! It shouldn't that tough. You can always tell when the Chinese translate anything into English. If look you closely enough on pages 18 & 19, whenever the directions refer to "manual recording" one of functions that they don't specify is the recording of 1 tape onto another. The way that this manual was written the writer apparently didn't envision that anyone would want to do tape-to-tape (dubbing) recording.
On pg 18 it says to load a recordable (blank) tape into the B side deck. Easy enough. Next comes the tough to discern part.
In section 2 where it mentions "For Manual Recording and Sound Mixing:" Select the desired source to record or mix. In your case that would be the A deck. Here is where they needed to take a little time and explain that tape-to-tape recording is one of those possibilities. Notice that you'll need to place the B deck in standby. Then select the REC PAUSE/START to start the B deck & then (this is another place where they needed to be more clear) you'll need to simultaneously start (press the play button) the A deck which would be the recording source. In the future just remember that the A deck is the source and the B deck is the destination.
Good luck.
2answers
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
