RCA RP5022 Digital Voice Recorder Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to unlock a 64m digital recorder - RCA RP5022 Digital Voice Recorder
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • RCA Master 102,366 Answers
  • Posted on Jan 31, 2012
RCA Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10429301
Points
622693
Press and hold [MENU] for three seconds.
RCA Digital Voice Recorder RP 5120 won't unlock?
Question edited for clarity. The words 'want' and won't are interchangeable.
Question moved from Cars and Trucks category.
It appears to be a well known issue.
https://www.google.com/search?q=RCA+Digital+Voice+Recorder+RP+5120+won%27t+unlock
Need to unlock din lock
By 'Unlock din', do you mean unlock the region the recorder uses, unlock the din input or unlock the tray or what?
When recording and you see 'unlocked', it means the DIGITAL signal you are trying to record is unclear or missing.
If you are trying to record a signal from another region disc, it will not copy. Add a little detail.
1helpful
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
3helpful
3answers
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nvidia GeForce4 440 Go 64M NV17M version
The lastest Nvidia Driver can always be found at www.nvidia.com
9helpful
2answers
How do i unlock a rca digital recorder model rp 5020a? I have tried holding down the menu button but does not work.
Normally, by pressing and holding the menu button down will lock and unlock the recorder. Since this is not working for you, you can unlock it by opening the battery compartment on the backside of the device and removing one of the batteries and then placing the battery back in and closing back the compartment. This will unlock the device also allowing you to use the functions. When I took the battery out for a split second it did not erase my test recording, but leaving the battery out for a long period of time may erase anything you have saved. I just wanted to make you aware of that. If you need an owners manual you can click the following link which will open in a pdf format for RCA Digital Voice Recorder Model # RP 5020A. I hope this helps solve your problem.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You.
1helpful
Unlocking the DM-20 digital recorder
Unfortunately if you are unable to unlock using the Lock Unlock feature. You will need to format the device. This will erase all data and unlock the machine to be able to record to it again.
8helpful
2answers
64m RCA Digital voice recorder user manualfor free
How do I unlock a 64m RCA digital voice recorder?
3helpful
2answers
Ddigital voice recorder rp5022b
The only way to unlock is to hold the menu button down for three seconds. This will lock or unlock the recorders functions.
I Keep getting the message: "dig. unlock" when I go to record a CD
Here is what I grabbed from the manual.
The message Dig.Unlock Means:
"There is an incomplete connection of the digital input jack during
digital input recording, or the input signal is not being input properly
due to some other factor."
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
