SOURCE: forgot the security code
hi if the phone is asking for the security code as soon as you switch it on then i can give you the master code that resets the code to what it was when new usually 12345 the code only works if its asking for security code when you switch phone on.
Also the code is only accepted if the code hasnt been entered wrong more than 5 times if it has been entered wrong more than 5 times then the code wont work the code is in my next post ok let me know if you need further assistance ok
SOURCE: Nokia 6681 forgot security code
If you want to reset your security code, use 0110452157 as your security code and change the current code.
Call me on +919917436086 if you have another problem.
SOURCE: i want to reset my Nokia E63 factory setting.. for...
When phone is off try using this key combo: on/off + * + 3
