Sony Ericsson W910i Cellular Phone Logo
Posted on Mar 01, 2011
I have sony ericsson w910i and the button at the top(slider) is got the problem,when i push the button it dont have any reaction. Whats wrong with my handphone??
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
3803
Points
57
I used to own this phone and had a friend that did too the big problem with this phone was the fact that buttons did break and no one really has a fix. All i can suggest is that you go to a credited repair shop if the phone means that much to you but i ended up replacing mine after the keys started to snap and then buttons started to stop working. It's one of those devises that always has problems..
Sorry for the bad news, Hope it helped though.
Adam
30helpful
3answers
I want to downland whatsapp sony ericsson w910i
i want to download whatsapp for sony ericsson w910i
3helpful
2answers
How to unlock?
To Unlock the Sony Ericsson W910I Model mobile from the Network lock You can use the Unlock Code You can get the Unlock Code at
http://www.wickedunlock.com/sony-ericsson-w910i/rs11wp9/ and Unlock the mobile following the Free Unlocking Instructions Below............
Sony Ericsson W910i Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson W910i mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W910i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W910i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson W910i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2
2helpful
When i make a call on my sony ericsson w910i,the person on the other end cannot hear me,any ideas whats wrong here? thanks in advance
OK Your talk back speaker has faulty due to dirt in your phone or needs to be replaced.
If you can Open the phone Your self, you can just clean it up and it might start working again or you change by buying another one to replace the formal one.
3helpful
2answers
I want to unlock my sony ericsson w910i fre how
hi friend,
press * and then press the right soft button to unlock if it doesn't works check this out Unlocking your Sony ERICSSON W910i is just the start of roaming freedom. This safe, simple process is one of the easiest ways you'll ever find to save money. The unlocking code and five minutes of your time will enable you to use your handset in ways you never thought possible.
We need only a short time (no more than 12 - 24 hours ) to generate your Sony ERICSSON W910i subsidy code. The sooner you place your order, the quicker you'll receive the unlocking code and be on your way. Both ordering and entering the code are easy. Just follow the instructions.
How It Works
  1. Select your phone and fill out our order form
  2. We will email your unlock code along with easy to understand instructions on how to enter it.
  3. Put in a different SIM card and enjoy your new freedom.
Once you have received your Sony ERICSSON W910i unlocking code, it is very simple to enter it:
  1. Remove the SIM card. Turn your handset ON
  2. PRESS the left arrow ONE TIME
  3. PRESS the * button TWO TIMES
  4. PRESS the left arrow ONE TIME
  5. The message "Personalize with MNC2" will appear
  6. You may now enter the Unlocking Code we sent to you. It may be necessary to PRESS ENTER or OK
    ERICSSON
    -W910i-,K850i-&-W890i-UNLOCK_...%20-">cgi.ebay.co.uk/UNLOCKING-FOR-SONY-ERICSSON-W910i-,K850i-&-W890i-UNLOCK_... -
hope this helps u
thank u for using fixya
please rate me............................
regards
sivaranjini
1helpful
Memory card does not lock into place for Sony Ericsson W910i
Some of the Sony Ericson phones have a little slider that slides back over the SIM card. This slider takes a bit of force, but be careful. Hold down the SIM and slide the retainer over the edge if the SIM.
Aug 10, 2009 • Cell Phones
My Sony Ericsson W910i hangs and restarts!!
hanging problem is due to torjn
just format the phone and it will be ok
sagar
How to put new fascias on w910i helllllllllllllp
  1. Turn off the phone.
  2. Remove the 4 screw covers on the back of the phone, 2 on the top of the main body and 2 at the top of the slider.
  3. Take out the 2 screws at the top of the main body.
  4. There is a 3rd screw on the right hand side of the phone above battery pack, take this out. dont forget where each screw came from.
  5. you can now remove the back plate.
  6. next you will need to remove the 2 screws on the top of the slider.
  7. Remove the battery pack.
  8. (make sure the slider is OPEN) You will see two screws on either side of where the battery pack was. Remove these.
  9. You can now Remove the front plate.
Bassically uncrew all the screws. take it apart, put your new stuff on and then do everything again backwards.
Not working atall
its a software fault it needs the software rebootin
Had my sony ericsson w910i slider unblocked/unlocked for 3
sorry to say the phone was not unlocked what you should do is try online at topsony.com.
2answers
Sony ericsson w910i keys
mine has done that with the ok, L-select, R-select, end call, start call, deleate, and numbers 1, 4, 7
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
