White - front left positive
white with black stripe - front left negative
grey - front right positive
grey with black stripe - front right negative
green - left rear positive
green with black stripe - left rear negative
violet - right rear positive
violet with black stripe - right rear negative
Red- accessory (power that is only present when the ignition switch is in the on or acc position).
Yellow-constant power (keeps radio stations programmed, time set, etc.)
Black -ground
Other wires are used for hooking up an amp, power antenna disc changer, etc..
Clarion's FAQ is also available if you need more information.
http://www.clarion.com/us/en/support/faq/Audio/index.html
