Does the DSL router have a model number? Also for the public address, can you give me the first couple of digits. I just want to make sure it is truly a public IP address and not a class A or B private address because only an ISP can hand out public addresses.
If the IP address on eth0 is indeed private, I am guessing you have to get into the DSL router and set a static route to point to let it know about both of the the ar410 networks on each interface. Keep in mind it might not understand VLSM so when you static route in the DSL to the 192 network you will only need to specify it as 192.168.18.0 as class C default mask is 24.
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting).
If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes.
If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
Conclusion
You have now configured your router for TCP/UDP port forwarding. If
you have a switched connection (ISDN or Analog), you will need to either
disconnect and
reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
