the 2010 is a legacy KVM DSR, and you might not have the same features that are present on the 8035 model. the settings to connect to the 2010 with a NullModem cable are 9600, 8, none, 1, none (same as Cisco settings).
The 8035 comes with a special adaptor which is DB9 to RJ45 and it comes in the box.
I hope that answers your question.
As far as console logs goes, no such thing on the DSR line.
Well, what can I say? you only need a cat5 ethernet cable with rj45 plugs and plug one side in your computer and the other in the wallplate, beside that with this information I can not say anything else.
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)
You can get replacement dongles for your card at http://www.buynetgear.com
or you can call 1-888-305-7440 Monday - Friday 8AM
to 10PM Eastern Standard Time.
Either your wallmount is not correctly crimmped according to the standards or your cable is not correctly crimmped according to the standards. So its better you crimp the cable and fix the R.J 45 connector in the sequence given herewith.colour coding of the cable:-
1-oranage white
2-orange
3-White green
4-Blue
5- White blue
6-Green
7-White brown
8-Brown
The same Sequence should be at the wallmount and at the R.J 45 connector.
