JVC GZ-MG130U Camcorder Logo
Posted on Jul 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recording. How to disable onscreen icons diplaying on record?
Cannot find the way to disable displaying onscreen status icons - as like as time, battery , mode and others during direct recording to Toshiba DVD recorder via RCA connection
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jul 29, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957165
Points
33084
Go to camera Manu and check Display properties. There you will find display option on LCD or Video Output. select it Display On LCD.
1helpful
How do I disable the internal microphone on a Dell e6400?
Hi Jamiescoffee,
You may want to follow the below steps to disable Microphone:
(1)Right click on the speaker icon in the status bar.
(2)Select Recording device.
(3)Right click on Microphone array and disable it.
However, if you want to enable this later on you may just right click on the same screen and select show disabled device. Right click on the device and enable it.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Disable mic on xps m1730
Right click on the speaker icon in the system tray (bottom right, next to the date/time) and select recording devices. It will give you a list of whatever devices you have on your computer that are designated to record sounds. Choose the on board microphone, right click, and select disable device.
2helpful
Hi, I have a sony handycam hdr-cx160 with I bought a np-fv70 battery and my problem is that my camera turn off after I spend some time used it, Like 2 or 5 minutes. it is charged, the camera recognize the...
Hi luismasramir ,
Seems to be the case where the battery is not fully recharged , Please follow the below steps :-
  1. Please make sure that you charge your battery fully , till the time you see an indicator for the battery being fully charged , or may be you see an icon in the display screen with the charge status.
  2. As far the 6.30 hr duration that you have mentioned, this duration reflects the time that you have left for total recording space on your disk or memory card depending on your current source for recording.
  3. The above duration is not to be confused with the battery usage time.
Hope his helps ...:)
Quickcam not working with blue snowball mic. why
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Does the Logitech C120m webcam have a built-in microphone
Check
Plug in your webcam
TEST SPEAKERS
Right click on volume graph and check 'Show hidden devices' and 'Show disabled devices'
If you have a webcam mic it will now be displayed.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Does it have a built in microphone?
Interrogate the information in your 'Recording' file
Plug your webcam in
TEST SPEAKERS
Click "Recording" tab.- check both "Show disabled" and "Show disconnected"
VX-3000 microphone still enabled with headset. Is
TEST SPEAKERS
In lower drop-box display "Use this device enable" click OK
Restart computer
1helpful
My microphone and speakers won't work at the same time
You do not say what the webcam model is or what the OS and if you have desktop or laptop
These instructions are for laptop and Vista
TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Similarly disable any other unwanted mic Click "Levels" tab and set slider to 60% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
1helpful
Can't figure out how to diplay date on recordings
You should have given details of your Camera.Anyways I'll tell according to Canon A460 because I have same and other cameras also generally have similar settings. First using Funciton set the size to Postcard size (with a Clock icon). Now using Menu button go to Date Stamp option and set it to 'ON'. you are done.
Please rate me appropriately.
Apr 18, 2009 • Cameras
1helpful
2answers
How do i disable my built in microphone?
double click on the sound icon in sys tray to access properties and disable from there or just turn the slider all the way down
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
