Your owners manual describes how to perform an incline calibration. Here are the instructions.
Start the machine running. Press and hold the incline up button. While the numbers are changing, remove the safety key. Reinstall the safety key. The treadmill should rise to maximum incline, then lower to minimum. After completing the cycle, the treadmill should function correctly.
If not, you may have a damaged wiring harness (caused during assembly) or a defective incline sensor.
If the sensor is defective, you will need to replace the incline motor.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
