SOURCE: wont drain burning smell
if it smells electrical then it is the motor and just because you replaced it months a go that dont meen anything i have seen them come off the shelf and be bad not saying ddty that this is your issue but it sounds like it a bad solinoid chances are very slim I would look towards the motor to find out when machine quits lean machine back on the wall so it dont fall on you and put your hand on the motor if it is hot then it is over heating and needs to be changedplease let me know what you guys find and if i can help you in any way
SOURCE: Last time I used my oven was last night and
yes i would call your gas company they come out for free and check for leaks.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: Fridge blows horrible smell
poss drain holes blocked,use a syringe to blow through with clorine bleach.(clorine will gas off so no after smells)
SOURCE: My washer smells horrible.
Despite washers remain with some residual water in the pump and wet components it should no be so critical as you are indicating especially if you cleaned it as you stated. You are not describing the smell but try to isolate the source, like the washer drainage point (odors coming from sewage), behind the washer, and inside or under the washer where the mechanical components are. It wouldn't be surprising to find a dead rat, lizard or pests in there. Sometimes even wet laundry falling behind the appliances stinks strongly. Be safe moving and reaching on difficult places. Good luck.
