Jabra Stone Bluetooth Headset Logo
A
Anonymous Posted on Mar 01, 2011
The jabra stone device will not pair with my mobile phone. It was paired at one time but has since quit working.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
209
Points
Depending on the phone, Some phones need to be set to be visible so that Jabra can find it when it is ready to pair.
I would delete the paired entries on the phone and do a fresh pair to the phone.
Do let me know if you are able to do this or can chat and walk you thru.
  • mm2giggles Aug 13, 2011
    Same here! Happened to me a month after I bought it last april. Verizonu tech couldn't figure it out either. They just swapped it for me then, but now this one is doing the same thing. But since verizon is on a strike(august), I'm not sure I want to try swapping it again; even then, the receipt is more than 30 days old now, so they probably wouldn't swap it anyway.
    If this is not your case type, maybe you just need to power off the headset out of. The cradle, then turn it back on(and hold the button in until pairing mode engages). If you hold it longer than needed, the pairing speech out of headset will restart before it finishes its presest pairing speech. Hope this helps! Jabra stone2
Need help to accept calls answering with bluetooth
Not sure if you have provided the correct model. You need to pair the headset with the corresponding mobile phone and then accept the calls.
Refer this table on the link and select the correct Jabra model and the mobile phone model and you will find the correct instructions.
Bluetooth Pairing Guide
Dont no how to pair order on ebay no hand book
this is for the stone 1
http://www.jabra.com/sites/mobile/na-us/support/pages/pairingguide.aspx
this is for the stone 2
what phone are you trying to pair with the bluetooth headset?
the default codes for jabra headsets are 0000
1helpful
I am having trouble pairing the Jabra Stone with my iPhone 3gs. I have held down the stone button multiple times and nothing happens. Also i have turned it on and off multiple times, but it just wont...
Hi, Look for "Add new device". Hit OK.
the phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
I've reviewed Bluetooth headsets before, and I would have to say that the Jabra STONE is one of the sleekest looking. Its shape is designed with minimalist simplicity, with a shape made for either the left or the right ear.
This shape goes onto a charger that is perfectly made to accept the Jabra STONE like a puzzle piece. This charger is probably what sets the STONE apart from most Bluetooth headsets, as it can charge the headset as the user goes. A green indicator means that it has enough charge for one full time or more. The red indicator means that it needs to be charged.
The STONE can be charged with an AC cord or USB connection. Once it is charged, there is a pairing indicator that made it simple to sync with my mobile phone. It has about 12 days (288 hours) of standby time and 8 hours of talk time.
I found that pairing the STONE with my phone was quite simple. In a matter of seconds, it was connected to my phone and I was making my first phone call on it.
The sound for the STONE is pretty good, with dual microphones and their trademarked Noise Blackout Extreme and crystal clear sound and voice with DSP.
One of the big features that I found is the touch sensitive volume control. In other words, there is no buttons for controlling the volume. I welcomed that, and most volume controls on Bluetooth headsets are really, really tiny buttons.
Other features include the ability to connect to two devices at a time, and it can stream music from an A2DP enabled mobile phone.
This is the problem that I had with the STONE. I found that there isn't really a "standby" indicator. I found that using it was a hit or miss situation. If I just pulled it out of the charger, it would sync with mobile it would work. When my phone rang later, and the headset was out of the stone cradle, and hitting the "connect" button didn't help. In short, I had to answer my phone. The Jabra STONE failed me, but I remember having similar awkward experiences when I first used other Bluetooth headsets.
The Jabra STONE comes with the headset, charger, 2 Eargels, a belt clip, AC charger, and a USB charger. You should be able to get it on Amazon for about $90 as the price to this writing.
37helpful
2answers
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
4helpful
I have tried everything in the manual to pair it with my iphone 3GS 4.1 but it's still not pairing. The iphone is looking and looking but doesn't find the device. Even turning the jabra stone of and then...
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
6helpful
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
How do i pair sp 500 to my nokia n95 mobile
The Jabra user manual is located below - you'll need to reference it to determine which button is the Pairing button. After you turn on the Jabra, press and hold the pairing button until the blue light is solid (approximately 2 seconds). Set your phone to discover mode as follows:
Go to the Bluetooth menu under the Tools menu item
Select Options > New Paired device.
Select the device and enter 0000 as the passcode.
If you want the device to automatically pair when they are within range of each other, select the device and select Set as authorised.
That's all there is to it.
Pair with mobile phone
when you activate the Jabra put your mobile to search for the bluetooth device when it finds it then pair code is 0000....then it should be paired
13helpful
Jabra connection
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
