HTC Evo Shift 4G (2 GB) Smartphone Logo
Anonymous Posted on Mar 01, 2011
How can I delete an Adobe pdf file? - HTC Evo Shift 4G (2 GB) Smartphone
Anonymous
Level 2:
  • Expert 242 Answers
  • Posted on Mar 01, 2011
Anonymous
Expert
Level 2:
Answers
242
Questions
0
Helped
75933
Points
807
Open the file manager (install Astro File Manager from the market if there isn't one installed). Navigate to where the pdf file is. Tap and hold on it until the menu comes up and select Delete. Hope this helps.
Ray
  • Anonymous Mar 01, 2011
    Perfect! Thank you!
  • Anonymous Oct 05, 2012
    Finally!!! after Trying Tons of other Suggestions, this one worked!!
1helpful
2answers
How to Resolve PDF Error - The File is Damaged and Could Not Be Repaired?
You ca use PDF Repair Toolbox restores unreadable Adobe Acrobat PDF files with documents.
For more: https://www.repairtoolbox.com/pdfrepair.html
I installed adobe 6 professional a few days ago on win 7 computer. but the printer drivers were not installed. i am not able to create pdf documents. also, when i try to download any pdf file from a web...
I am not 100% certain but I am not sure you can use that old a Adobe version with Win 7. The current Adobe Pro for creating .pdf files is now version 9 for Win 7. That may be part of your problem. Consult the Adobe website and see if that older version will even run in Win 7
5helpful
4answers
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
54helpful
3answers
Invalid plugin detected. Adobe Reader will quit error appears, pdf not accessible
INVALID PLUGIN DETECTED.
Go to C:\Program Files\Adobe Reader 9\Reader\Plug_ins\.....delete the Babylon folder. It worked for me!
1helpful
HOW DO I DELETE ADOBE PDF FILES FROM NOKIA E 63
You can see that pdf file in file manager in the corresponding memory location. From there you can delete it. Hope you will succeed...
3helpful
2answers
Cannot open pdf attchment
I had the same problem, and I solved it the following way.
The problem is that as soon as the temporary folder contains more than 100 "Document.pdf" (Document.pdf",Document(1).pdf",Document(2).pdf" etc...) it will not allow you to open anymore.
The only way around is to go in the temporary folder and delete one or more "Document.pdf"
To open the Temporary folder:
-open any pdf document that does not have this problem,
-Go to File and then to Save As.
Directly from there you can delete the "Document.pdf
You will then be able to open the Digital Sender scanned pdf document.
Unable to download pdf file
Uninstall all Adobe software what ever version you have, than go to start>search>all files and folders, select local hard drive if it is not, than click more advanced options, select first three things in the list and than type adobe in All or parts of the file name. When it finds folders and files select them all and press DELETE. Than empty your Recycle Bean and restart your computer once it is up download new Adobe installation file and install it again. I know that this is pain but you will have to get rid of all damaged files used by adobe reader.
Viewing pdf files on internet
Uninstall Adobe Reader, shut down completely for at least 30 seconds, and then restart.
This releases "Locked files" for deletion.
Then do a search for "Adobe", in 'all files and folders' - search with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those files found.
You should do this search and delete whenever you un-install any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
BEFORE RE-INSTALLING Printmaster
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling. Go to the Adobe website and install the newest Adobe Reader 8.1 program.
http://www.adobe.com/products/acrobat/readstep2.html
2answers
Damaged adobe reader 8 damaged
if you get this error message when you try to open a particular file. the problem could probably be in the .pdf file and not the software. if this is not the case, uninstall adobe reader completely and reinstall it. if this docent work. download the latest version of adobe reader from the adobe site and try installing it again.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
