How to configure laserjet 2015 network printer
Please perform the following:
Unplug the network Cable:
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
Network reset
A network reset changes all network system parameters in NVRAM to the factory defaults. During the network-reset process, all button presses are ignored.
Use the following procedure to perform a network reset.
Now plug in the network cable and then wait for 5 mins.
If the Attention and Ready lights illuminate before you release the Job Cancel button, start again at step 1.
Then print a configuration page and check the IP Address.
SOURCE: how to connect to network printer hp laserjet 2015 PCL5
I cannot connect to hp laserjet 2015 PCL5. wia network...
im
using 64 bit windows 7, and tell me that Windows cant find a driver for HP.........i install driver and nothing........
i can connect to my printer it was reset mistakenly and has an ip configuration of 0.0.0.0
