Pyramid 719A 7-Band Car Equalizer Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not sure of the best setting for the best sound and bass
Arcesso
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on Feb 28, 2011
Arcesso
Expert
Level 2:
New Friend:
Answers
54
Questions
0
Helped
13410
Points
166
Equalizing audio is truly a matter of preference and depends largely on the song you are listening to. You can try this guide to get the best sound for you.
I just connected two sets of 901'a to Sansui G901 receiver. The sound is TINNY no bass at all. I've tried different connections and nothing seems to work. I've used two different EQ from bosse series
Either there is NO bass on the recordings (if you listen to it with headphones does it have bass?) ...OR...you've wired them out of phase. Connect only one(1) Bose 901's to just one side. Is there bass? Then connect the other side. IS there bass? If not reverse the phase (+ /- connections) and see if the bass comes back. Once that is done and there is BASS, then add the 3rd and then the 4th speaker. .Are you sure your Sansui can handle a lower than 4 ohm load???
1helpful
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
I have a problem with my z-5500! the bass is really bad, on all the effects. my friend has the same pare of speakers han his bass is really good. what should i do???
Always make sure that your computer settings for audio are checked and set accordingly and that all the equlizers and audio programs that are installed and controlling your audio sound output are accounted for and adjusted properly.
My bass drum pad doesn't work I get a drum sound when I put the lead into the module but nothing from the kick pad. I tried another lead to a tom and the bass drum but this wouldn't work either. I...
If you have already tried a different cable and it didn't work, then the issue might be with the bass drum pad itself. You can try the following steps to troubleshoot:
  1. Check the connection: Make sure that the cable is firmly plugged into both the bass drum pad and the module. If the connection is loose, the signal may not be transmitted properly.
  2. Check the sensitivity setting: Check the sensitivity settings on the module for the bass drum pad. It is possible that the sensitivity is set too low, and the pad is not registering hits.
  3. Check the pad: Check the bass drum pad for any visible damage or wear. It is possible that the trigger inside the pad is damaged or malfunctioning.
  4. Reset the module: Try resetting the module to its default settings. Sometimes, this can fix issues with individual pads.
If none of these steps work, it may be necessary to open up the pad and check the trigger mechanism inside. If you are not comfortable doing this yourself, you can take it to a repair technician.
1helpful
What are the best settings for bass , treble and mid in order to get the best sound
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
What r the best freqency settings for my jvc rx-701v super a home stereo receiver. I like BASS
There isn't any "best" setting. It's whatever sounds good to you. So if you like bass, crank it up and enjoy.
Bass only going to rear speakers. How do I get
Hello michaelandta,
Check your filter settings on the front channels. It sounds like they may be set to "high pass" which would eliminate the bass frequencies. If you are using the amp to power normal speakers, it's usually best to set the filters for "full range". If the amp only has "low pass" and "high pass" settings, turn them both OFF.
Hope this helps.
Want too get best low bass i can from this amp
you turn your low pass filter (LPF) on the amp down to your desired frequency, but the box you have it in will drasticly change the sound (if you werent aware) hope this helps!
No sound from my logitech z4 subwoofer
Is there sound coming from the 2 speakers?
Subwoofers are designed to only play bass, you shouldnt hear much acoustic sound coming from it at all.
The best way to test that is to play a song with a good amount of low bass, see if you hear it coming from the woofer, or can you feel the woofer vibrate?
If there is a hole in the side of the woofer box, when you are playing the song is there any air coming out of that hole to the bass line beat?
I dont know how you have your wiring set up, but if it still isnt working please check to make sure that you have the wiring plugged in properly.
If there is anything else I can do to help please let me know. I hope this fixes your problem.
3helpful
2answers
Bass amp settings
For rock and slapping you are going to want to set the Bass and Treble controls high and the Mids low. For music such as Jazz you are going to want more mids so that your sound will be fatter. If there is a button marked "Mid-Scoop" you'll want that on when slapping.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
