HP OfficeJet 6110 All-In-One InkJet Printer Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The power supply for my HP Office Jet 6110xi was lost during a move. I have been unable to get the power supply model number to be able to order a replacement. Can you help?Thanks
Anonymous
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
18430
Points
247
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
4829
Points
33
HP LaserJet Pro MFP M130fw. Error code 58.04 Laser jet pro mfp m130fw
Question edited for clarity and toss in a load of CAPS.
Question moved from 'Jet Office Equipment' category.
It's not good!
HP Color LaserJet Pro MFP M477
Printcopy.info https://printcopy.info > brand=HP > code=58
Code: 58.04; Display: 58.XX Error, Turn off then on; Description: The product has experienced an error with the low voltage power supply.
Missing: M130fw. ‎' Show results with: M130fw.
58.04 printer display error on powerup
HP Support Community https://h30434.www3.hp.com > td-p
Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ...
My printer is displaying, "58.04 Error power outage detected...
Jun 28, 2022
Laserjet Pro 400 MFP 451dn error message 58.04
Aug 5, 2013
My laser jet MFP M477fdw printer is showing 58.04 error cont...
Sep 22, 2021
HP M451 Error 58.04 - HP Support Community - 5830295
Nov 1, 2016
More results from h30434.www3.hp.com Missing: M130fw. ‎' Show results with: M130fw.
Error Codes > HP > LaserJet Pro MFP M130 > Code 58.XX
Code: 58.XX; Description: The product has experienced an error with the low voltage power supply. • 58.04 = Low voltage power supply malfunction; Remedy: 1.
I need a Manuel for my printer hp office jet all in one?
Could you please give what model number your office jet is so we can get the correct information for you. This number should be on front of printer near the office jet name.
I have a HP office jet printer t45 with an error message c0030002, how can I fix this problem
Try this. Hope it will help you.
This indicates an obstruction to the print carriage. Turn off the power,
c003 xxxx
open the top cover, and look for something preventing the ink car-
(x = any
number)
tridges from moving back and forth.
If the problem persists, close the top cover, turn on power, and open
the top cover again so the print cartridges move to the center. Remove
and reinstall both print cartridges. Close the top cover. Then remove
the power plug from the back of the HP OfficeJet, wait four seconds,
and plug it back in. If the front panel directs you to, realign the print
cartridges by pressing Enter and following the instructions on the
sheet that prints out.
Note:
For any error code not listed above, remove the power plug
from the back of the HP OfficeJet, wait four seconds, and plug it back
in. If the error code persists, contact Hewlett-Packard for assistance.
G85 desk office jet
According to Intuit it may due to inappropriate printer driver settings, for resolve this issue follow these tutorial steps Problem Printing Transactions to HP Printer and if not have enough technical knowledge or need any guidance during this process follow Intuit Support Number .
2answers
I accidentally deleted my hp officejet 6110xi all-in-one. Now I can install it, but it doesn't print. Error message comes up in the box. I am running Vista Home Premium 64 bit. Thank you,
Go into your [Device Manager] Expand the Universal Serial Bus Controllers section and you should see USB Print Support. Double click that and under the Driver tab, click on the [Uninstall] button. After uninstall, power reset the computer. Once powered on, plug the printer back into the computer. This should re-do the installation process properly.
Lost the power cable during a move and need a replacement.
The item number for the power cord is 8120-8882 The item number for the power supply is 0957-2094 You can order them by clicking here or by clicking here
Unable to install printer. Disc supplied will not load. Printer is a HP Laser Jet P1005 Brought 11/8/2008 from post office
Go to hp.com support downolads. enter your model number and you should be able to download updated software and drivers.
Printer part
Try using HP's PartSurfer website to find the power cable. It has the complete inventory of all HP parts, searchable by part number or model number.
You can get the part number off of your old power cable, or search by " Officejet 6310 ". There are actually several sub-models of the Officejet 6310: Q8061B, Q8063A, Q8062A, Q8077C, Q8061AR, Q8061A, etc. Look on the barcode label on the back of your printer to find your specific sub-model number. (They probably all use the same power supply, but it's best to be as precise as possible when looking up the part.)
k24674
Grand Canyon Tech
Grand Canyon Tech
