You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
HDMI is the same, if not better quality than Optical audio. The receiver will not recognize a video input from one source, and an optical audio input from another. It must be all optical into the receiver and HDMI into the TV for this to work, or all HDMI into the receiver. Let me know if this works with a thumbs up =]
Either
A. All HDMI into Receiver
B. Optical into the Receiver, HDMI into the TV
I have done this already....do you know this model?
