Dear sir i want to start new work shop so now a day new technoloy lounched key progamming and digonositice tools
are needed so suggest me my mail id
[email protected]
You didn't mention what vehicle you have. Nearly all newer vehicles have transponders in the keys so that only the right key can start the vehicle (you can't hot wire it or break the ignition lock) and the remote starter would need this keys' radio ID code to start the vehicle. If the computer was replaced this code may have been changed so the remote starter wouldn't work and would need to have the new ID code programmed into it.
The way I understand your question is your vehicle main computer has been replaced and it is not working properly. Since you say you cannot start it, have them come and get it and do what ever additional programming is required. You cannot do this yourself. If this is a remote start issue and you can start your car with the key, take it back and have them make necessary repairs.
Thanks for your interest in FixYa.com.
Is this your device: http://www.amazon.com/Python-1400XP-Remo... If this is the case, I don't completely understand what you are asking. I am thinking your vehicle computer was replaced ... you have a Ford? and Ford replaced Ford's computer in your ford vehicle? If this is the case, Ford should be able to fix a Ford product. BTW, you have not mentioned things that would have been helpful in responding to this question.
If that was the case (Ford replaced your Ford's computer) and now your 'add on' after market 1400XP remote entry will not work as a result, that is a little different. Did you do the install of this after market device? If you did, you received a install manual. I must refer you to this manual for instruction. If this install was done by a shop, including your Ford garage, who ever installed it should be able to set it to work properly, and if Ford, I would demand they set it up for you.
Thank you for allowing me to add further information to my original response.
My seat of the pants reaction reading this over again is your remote start function was disconnected when the new computer was installed. If that is the case, the start relay just needs to be reconnected.
My spell checker un-capitalized Ford. Sorry for the inconvenience.
Go back to Circuit City ... ops ... they are out of business.
My next suggestion is if you don't have the install manual, get it from the manufacturer or other source. Here is one: http://www.retrevo.com/s/DEI-1400XP-revi... I recommend you review the manual and review the system in your car. You may be able to figure out the trouble. There is probably a 1-800 support/help number in the book and you may get some help by calling that number. If that fails, you will have to take the car and the manual to your mechanic to solve this trouble.
I am presently in the midst of installing a remote lock in my older vehicle. Mine is wired exactly per the instructions in the book. I have spoken with the company guru on 4 occasions. This morning, I had to go over everything - EVERYTHING - with the rep like I had never had a conversation with him and the upshot is I have to return the control module to him AGAIN. I am very frustrated - particularly knowing that my vehicle is exactly like the vehicle owned by the company help guy that is 'helping' me. My device is from a different manufacturer. I hope your experience is better than mine. My vehicle has been 'tore up' for more than a month as I continue to fool around with the darn thing. Mine has a remote start capability - however - based on the luck I have had so far, IF I get it to unlock the door I will not press my luck!
Good luck ...
I went to the ford dealer.as you advised.They told me the key that is with the 1400xp has to be reprogramed and they con not do that.Where can I go to have that done? Glenn
This is not a Ford product. It was bought and installed by Circuit City.
