Computers & Internet Logo
Posted on Feb 28, 2011
I am trying to set up my new roku player and the set up menu says to link my computer to my roku player then from my computer go to roku.com/link and enter my code. well there are 1000 roku.com/link sights and nho where to enter my code!
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 28, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
959
Points
12
This link will take you to a page that when I go to it, only asks for a code, there is barely anything else on the page. Can't imagine this not working! https://owner.roku.com/link
Trying to set up Netflix on my roku
Hello
1.Press the Home button to navigate to the Roku Home Menu.
2.Select Settings.
3.Select Netflix Settings.
4.Select Deactivate this player from my Netflix account.
5.Select Yes. The device is now deactivated.
For any help visit us: www Roku Com Link
tip
Roku, How To Setup a Roku Player
You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to www.Roku.com internet site and set up your account with them, they will need info on how to bill you if, you use a pay chanel. So they will need some bank account info, Or you can use PayPal. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to input your Link code, or go to http://owner.roku.com/link to input the code. Then go to the Roku menu screen and finish the setup with your Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this, you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks to have some trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account over 50. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading. Hope this helps FixYa up.
4helpful
Czn't find roku.com/link
If you have the code, go a computer, open a browser windows and go to http://www.roku.com/link
to enter your code.
Enter the link to complete your setup.
If you are still having difficulty visit http://support.roku.com/entries/244199-how-do-i-set-up-my-roku-player to get a step by step walk-through.
1helpful
How to hook up to roku
See this tip I have posted here on this site. >>> Setting Up A Roku <<< and read this, You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to Roku's internet site and set up your account with them, they will need info on how to bill you if need be. So they will need some bank account info Or you can use PayPal. They need this info in case you order a pay for movie or swap to a paid channel. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to receive your Link code, write this code down and go to your TV, Roku menu screen and put in the Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading.
1helpful
Trying to hook up roku wireless player, need pass word?
11helpful
3answers
I"m trying to set up my roku, were do i enter my
to enter your code.
6helpful
2answers
Where do i enter my code for mr roku player
to enter your code.
Grand Canyon Tech
Grand Canyon Tech
