Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Hi Andrey,
Did you mean P02?. If yes, means that carriage error occurs on your printer. This error is another format of error code 5100. It describes the same thing that applicable for all Canon inkjet printer model.
I hope the following link would be useful for you. Thanks.
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100. To solve this error follow the given steps:-
Turn off printer
Remove both the cartridges from the printer
Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
Return the cartridges
Turn on the printer.
Error will be removed. I hope this solution helps you Let me know If you have any more Confusion, questions or issue regarding your problem Thank you and Keep using FixYa!
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100. To solve these follow the following steps
Turn off printer
Error will be removed but If the problem is not resolved, then best option is to take it back where you purchased it or contact Canon service center
about the error code or To get support by Canon on phone, then call at 1-800-OK-CANON (1-800-652-2666) They will surely solve it. I hope this solution helps you THANK YOU and Keep Visiting FixYa!
Turn off printer
Error will be removed. I hope this solution helps you Your token of appreciation in the form of Four thumbs and testimonial will be esteemed. THANK YOU and Keep Visiting FixYa!
Hello and Welcome Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100. To solve these follow the following steps. I hope it works
Turn off printer
Error will be removed If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help Please click on Four thumbs which are given below to this solution "if it is helpful" THANKS & Keep Using Fixya
Turn off printer
Further assistance i am here to help Please don't forget to click on Four thumbs which are given below if it is helpful THANKS & Keep Using Fixya
Hello thanks for using FixYa Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100. To solve these follow the following steps. I hope it works
Turn off printer
Error will be removed I hope this solution will helpful for you Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful THANKS & Keep Using fixya
