the green light is power indicator not mic level. the green light should come on when powered up. remove mike cable and the see if green light comes on, If it does power down and connect mike and cable (hopefully you have a good quality one and not a toy)
Call Behringercustomer service. Where did you buy it from, if new it is under warranty and need to replaced with another new one. It is not an audio mixer the yellow and right lights are for clipping.
Look like the light in side stay on , you will try take the bub light out and see if it working fine you need replace new door switch . Let me know how it work i will tell you Next step for saving to fix the door switch
yellow blinking or not? if blinking your lamp cover is open that could be you forgot to reconnect the wires back to the lead that monitors the lamp. It's a 2 wire molex connector either black or white that will be laying next to that light cover you removed to get to the bub. this connection may be labeled "CD". iF SOLID it is a high temperature indicator, the set would have to have a lamp that works for this, so I'm guessing the lamp hasn't turned on yet. the fast blinking green is your set initializing, testing circuits and fans and yup lamp cover switches.
DISCLAIMER : I take no responsibility for any damage you may cause to
your Axim. The parts and proecedures described in this guide refelct my
own experience with my own Backup Battery (BuB) in my girlfriend's Axim
X3. Your mileage, parts, anbd experience may vary.
Tools needed for successful BuB replacement:
1. fine tip jeweler's screwdrivers (helpful if you slightly magnetize the tip)
2. Varta V20HR rechargeable NiMH battery
3. electrically conductive silver epoxy
4. strong needlenose pliers
5. electrical tape or heatshrink (razor blade or scissors to cut to shape)
But here it is step-by-step:
1. Pop little rubber caps from 4 corners of back covers. Disassemble
Axim X3 with small jeweler's phillips head screqwdriver. Be sure to
plave all parts in a plastic bag or other container (4 scres rear
cover, 2 screws near port). Disconnect the ribbon connector towards the
bottom of the PCB and the speaker wire (also on the lower portion of
the PCB). Backup battery should be the green covered circular item
under the pcb).
2. Locate backup battery, Cut away BuB cover, & CAREFULLY use
strong needlenose pliers to grip and "roll" the leads off of BuB.Be
very careful with the leads.
3. Mix dime sized batch of silver conductive epoxy (do NOT hot solder
this battery, heat will lead to BuB damage and destroy lead connection
to wire).
4. Apply epoxy to both sides (not too much)and afix respective leads to
respective side (red lead goes to +, black lead goes to -). Secure
connections with some type of clamp (I used a binder style paper clip,
but a wooden close pin or something else that will hold the leads to
the BuB while the epoxy cures (Mine took 24 hours to cure).
5. Recover new BuB with protective covering (I use electrical tape cut
to the shape of the BuB. Covering WILL have to be form fitting to fit
back into Axim BuB "slot".
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
