Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
2003 GMC Sierra C1500 Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not
provide a switched power source. Run a wire to the fusebox or ignition
switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: I need a wiring diagram
http://www.modifiedlife.com/2003-gmc-sierra-c1500-car-radio-wiring-guide/
Here is a written diagram. This site, along with many others, offer a pre-wired harness for easy plug and play installation
