Polaroid T1234 Digital Camera Logo
Anonymous Posted on Feb 28, 2011
I need the manual to see what all the different settings are because its just shows little icons for the different settings
Anonymous
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
17654
Points
352
Here is a link to a pdf of the manual be sure that you have a pdf reader like Adobe Reader installed. Cheers!
https://www.plawa.com/download/19494/t1234%20User%20manual.pdf
  • Anonymous Feb 28, 2011
    thank you so much, i've been looking all over the internet for this and couldn't find it anywhere
Anonymous
Level 2:
Sergeant:
  • Expert 158 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
158
Questions
0
Helped
21102
Points
502
You can download the manual at the following link:
http://www.retrevo.com/support/Polaroid-t1234-Digital-Cameras-manual/id/23452ag303/t/2/
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1126
Points
16
You can download it from here:
http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/T1234-_S
look for the pdf icon in the right hand side of the page
How to add icons to desktop ?
Assuming you are on Windows 10... if right click on the desktop in a place where there are no icons, you will get a menu.
If you are showing no icons on your screen at all, hover over the View option. A sub-menu will show. make sure that "Show Desktop Icons" is checked.
If you are trying to have the common desktop icons displayed of "Computer", "User Filed", "Network", etc...
the bottom entry on the menu says, "Personalize..."
Click on that, click on "Themes" on the left, click on "Desktop Icon Settings" on the right, then click the check box for every icon you want on the dialog that comes up, click Apply and OK as needed to exit the settings.
If you are on a different version of Windows, the instructions are very similar, you may have to scout around a bit to find how they work in an older version of Windows.
2answers
How do I get to the menu or call register option to see missed calls?
if the notification icon for missed calls is not showing at the top of the screen then open the phone dialer screen. at the top of the screen you'll see a "call log" tab. click on that and you should see you call history, that is calls you've made, missed, or received.
May 02, 2015 • Cell Phones
Device stopped recording, or doing anything else. The screen shows a little lock icon. It is fully powered up.
The lock icon means you have switched the "lock" on ...this prevents accidental erasure of files.... if you need the operators manual go to www.olympusamerica.com ...manuals are under "SUPPORT".
I need the icon back on my Inspiron 570 desktop. It helps me adjust the volumn by showing a little meter that you can raise or lower. HOw can I get it on my screen . thanks for any help.
There are two reasons one due to the hidden desktop icons and the other due to different user login. If you have logged in using another user ID, try logoff and login to your ID.
If it is due to hidden desktop icons, then right click on the empty area of the desktop, select "Arrange Icons by" on the context menu, and then click on "Show Desktop Icons"
How do you set device in english, mine is in Spanish?
  1. Download English manual here.
  2. Tap the screen to bring up the Main Menu.
  3. Tap 'Change Preferences' icon (it has different name under it in Spanish, but you can view the icon itself at page 8 of the manual).
  4. Tap 'Show all menu options' icon (page 33 of the manual)
  5. Tap 'Change language' icon (page 36).
3helpful
2answers
How do i turn off the flash on cannon power shot SD 400?
The little lightning bolt on the right side of the function switch (3:00) gets you to the options. If you keep pushing it you will get the different settings. In the manual on Page 68 the different settings are given for the different icons.
For the manual Click Here.
Thanks for using Fixya. Happy New Year.
Show icons power
If you mean "battery power" icon...you need to go into the "Control Panel" via the "Start"button on the lower left of your screen and adjust your "Power Options" settings in the "Advanced" tab to "always show icon on the desktop". Windows defaults to not showing this icon. You need to do it manually as described above. Once done, it stays that way.
3helpful
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Wd passport file customizing
If you open the Computer directory and identify the drive letter for the WD Passport drive, right-click on the drive folder and select properties. The properties tool for the drive will open showing several tabs. Select the Customize tab and you will see a heading for "use this folder type as a template" with a drop down menu. Here you can select different categories for the folder and apply it to subdirectories also by checking the box below. This should give the folders more of a vista look! If you want to personalize further and add your own images to the folder icons you can also do this here. If you don't select the apply to subdirectories option you can manually apply different styles to different folders in subdirectories. If you don't like the way things have turned out you can also restore the default settings.
Hope this answers your question.
Have fun
5helpful
3answers
My computer screen got bigger
Press Control and + to make it bigger
Press Control and - to make it smaller
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
