Computers & Internet Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change the keyboard of a Samsung E352 laptop computer.
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
16630
Points
72
This site here has information on removing the keyboard for a Samsung laptop and may work with your model.
Anonymous
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
54
Questions
0
Helped
6192
Points
158
Just take it to ur nearest samsung service vendor..
HOW TO TURN MY WEBCAM ON A SAMSUNG
It usually works straight out of the box. When using for instance Skype, go into the settings and select the correct webcam. It should work from then on out.
My samsung ativ conputer keyboard back light will not turn on
click fn + f1 and change the keyboard light setting via the slider in the settings screen that opened up.
How to take the keyboard off a samsung rf712
just use your best judgement, see where the keyboard is physically located and unscrew the corresponding screws on the back side.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Delete key on laptop not functioning
Hook an external keyboard to the laptop, if okay! replace the laptop keyboard, if no change! there is a device drive issue, do a system restore of your computer back to an earlier time before this happened.
How do you remove keyboard
Remove a laptop computer keyboard by locating the keyboard screws marked by an icon, unscrewing the screws with a small screwdriver and gently pulling up on the keyboard. Remember that the ribbon will still be attached between the keyboard and the motherboard with insight from a computer specialist in this free video on laptop computers.
Read more: Video: How to Remove a Laptop Keyboard ' eHow.com http://www.ehow.com/video_4767076_remove-laptop-keyboard.html#ixzz1iR3ziDzl
Need to reset samsung notebook e352 back to factory settings.
Its not a cell phone. The easiest way is to restore from the 's supplied with the laptop. Just insert nr one and tell to restore to a fresh install Good luck Rene
3helpful
Can i download a user manual for a samsung np-e352 laptop
Open this link (Click Here), click "Free Download", wait for 60 seconds until the countdown timer resets, then again click "Free Download". It's a Pdf file which is zipped with winzip.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
3helpful
How do i replace a sammsung R519 keyboard?
Step one: Remove the two screws from the bottom of the computer that are holding down the Samsung R519 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Samsung R519 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Samsung laptop keyboard.
Final step: To insert the new Samsung R519 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Samsung R519 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
4helpful
2answers
Samsung Mobel NP-P500Y
What sign is it that it gives you? your keyboard may be set up for the wrong region. are all the signs like that? or just the @ one? In Windows XP to change the keyboard layout: Control Panel -> Regional and Language -> Languages Tab -> Details and the keyboard language should be English US.
for more details visit this website: http://www.starr.net/is/type/kbh.html
Hope that helps!
Caleb Scansen
Technician/Manager
Rimrock Computer Co.
2320 Zoo Dr. Ste D
Billings MT 59101
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
