Question about Water Heaters
I need to get a boiler manual for a worster 24cdi for lpg asap at no cost if possible
    Problem Solver:
  • 18 Answers
Follow the link below it has a free downloadable manual for Worcester 24cdi. Hope it helps let me know if you require anything more specific.
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/24cdi-rsf-discontinued-june-2007-literature
Posted on Feb 28, 2011
SOURCE:
Need to convert Paloma gas heater from natural gas to lpg in qld.
You can't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Among other things besides having to reprogram modulation, you'd also need to re-jet it and that's not possible in the field. NG and LPG jets are not the same due to vastly different operating pressures.
Some brands can be field converted but not Paloma/Rheem/Richmond/Rudd Tankless units!
May 18, 2014 | Water Heaters
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 08, 2013 | Water Heaters
Boiler Programmer user manual
contat worcester bosch they will be happy to send you a manual as you already have there product installed.
Dec 11, 2012 | Water Heaters
My Alpha 240E boiler does not heat water from the taps unless the radiators are on. I have been told this is because my boiler needs a new convertor valve, can I purchase a convertor valve and how wou
Its a diverter valve thats required not a converter as you state,it is not recomended to do it yourself ,you can get the valve easily from a reputable plumbers merchant ,alpha is a popular boiler, just supply the gas control no or boiler details to the merchant and the should be able to get the right divertor valve, then you just have to find a good plumber to fit it , it would be quicker and safer for some one qualified to change this.
May 19, 2017 | Water Heaters
How is liquid lpg system set up? i have a aqua star mod.125vp that i would like to install in my home, the liquid lpg. is the part im not shure about. thanks d.r.
The lpg either cylinder or gas tank must have a pressure reducing valve which sets the gas pressure to that required by the boiler.
After that valve the piping is the same as for any gas boiler.Where the pipe goes through the wall floor of similar - make sure the pipe has a sheath to protect it from gouges and or wet
The regs - Not sure about the USA but here in UK we have comply. different regs for tank or cylinder
The lpg supplier is a good source of info
Feb 16, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
24i boiler lpg water gets to hot
temperature control knob may not be properly connected and not actually turning the spindle behind it.
OR if the flow through the hot tap has become reduced over the years there could be furring in the heat exchanger
Aug 15, 2009 | Bosch Water Heaters
Boiler
this is a drain valve -like a water tap just close clockwise firmly -please advise me - there are some things you have to do now- please respond asap
Oct 31, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
368 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
