Sewing Machines Logo
Posted on Jul 29, 2008
Elna Primula 410 Bobbin Winding Question
Inherited my mother-in-law's old Elna 410 sewing machine, without a manual. Nice machine, sews like a dream, but I cannot for the life of me figure out how to make it wind the thread on the bobbin. On my newer Brother machine, simply sliding the bobbin knob to the right so it is near the stopping peg is all it takes to put the machine in bobbin-winding mode, but on the Elna this apparently doesn't do it. I have tried everything I can think of, but I can't make it go into winding mode. Help!
  • 2 more comments
  • Anonymous Mar 12, 2014
    I cannot sew with this... only wind bobbins. Model 11590 janome
    I cannot sew, only wind bobbins.
    Model 11590 Janome
  • Anonymous Mar 19, 2014
    lights flashing on right hand side of machine. can't program a stitch and can't wind bobbin
  • Anonymous Mar 30, 2014
    I have an old omega sewing machine and I am trying to wind the bobbin I figured out how to stop the needle from going up and down but when I press the pedale I hear the machine spinning but my bobbin doesn't spin What should I do
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2329
Points
11
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
  • atinfo Nov 01, 2010
    Unscrew the inner blue dial in the handwheel counter-clockwise until it stops. Thread through bobbin whole 1 inch. Donor spool on normal peg, thread around guide pulley on left side. Pop your bobbin on the top right peg, turn it until it fits the bobbin notch, and push it into the stabaliser. Push foot pedal.
    Once you're full remember to tighten the inner blue handwheel dial clock-wise until it's tight.
    Easy!
toolmanw5687
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Aug 31, 2011
toolmanw5687
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
4722
Points
23
Just fixed my moms. Take the top cover off, remove the arm, careful of the tension spring. clean the shaft hub. spin till you free it up then use a extra light oil and reassemble. Works great!
1helpful
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
I can not get the bobbin thread to catch, what should i do, elna primula 410
try a new needle--one for the fabric being sewed
rethread the machine--top and bobbin
make sure the bobbin is correctly inserted and turned the right way
also could be a timing problem, the machine may need to be checked
I inherited my mother's Elna Lotus SP sewing machine. She had the sewing guide inside the machine, but not the instruction manual. I need to know how about the bobbin and how to thread?
Hi Jeanne, you might want to check out my tip on early Swiss Elnas,
http://www.fixya.com/support/r10602655-acquired_early_swiss_elna_sewing
it should help you get the Lotus going. Lovely machine. If you are in the USA you may also want to contact White Sewing Center as he may have this manual available for sale or a copy of it. www.whitesewingcenter.com.
Remember to use the Elna 7 hole dished metal bobbins, there are 7 holes on the top, and looks like this11_7_2011_6_23_57_am.jpg
Always wind it and insert it into the machine this way. Don't use any other bobbin. Standard needles 130/705H, flat shank to the back.
Check out my other tip on bobbin winding too, it is important to keep tension onto the thread spool that you are winding thread off as the machine doesn't tension the thread for you. So you need to apply pressure to the top of the thread spool as you wind off, use the curved handle of your scissors on the top of the spool.
Feel free to connect to me and ask if you have any other questions, I have a Lotus TSP at home and its almost identical to the SP. Happy stitching.
2answers
I have inherited an old 'Brother' sewing machine with no manual
i have an old brother machine maybe back in the 60s-80s and the thread keeps coming out of the needle and i dont know how to do anything with the bobbin.i have no idea how to use the machine at all.i would love to learn any help.cant find any thing online to help.
1helpful
6helpful
ELNA CONTESSA 410
I have a Elna Contessa 710 Manual. If you think it will help I may be able to scan a copy and email it to your own email address. Plz supply email address if interested or still unable to thread machine.
Bobbin winder is stuck
It seems that the bobbin winder sensor needs adjusting and is best done by a service technician with the appropriate service manual to ensure correct parameters are achieved..........to locate your nearest Elna dealer, try ElnaUSA .....here
2answers
Elna threading and reverse instructions
Hi
I have a Primula 310
The reverse is located in the middle of the stitch length dial, you press in the button whilst you reverse.
When threading up any sewing machine make sure the foot is 'up' as this opens the tension disks and the thread goes between. when you lower the foot the discs close around the thread and add the tension.
Hope this helps
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
