If the touch screen of the Camcorder is not working, please
follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if
that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please
remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15
seconds, turn the Power switch to OFF position and then reinsert the battery
pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
I hope this information will help you to resolve the touch screen issue of the
Camcorder.
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body or the LCD module itself and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
that helps.
pack.
Camcorder.
