RIM BlackBerry 7290 Logo
Anonymous Posted on Feb 28, 2011
Hi I mestup my Blackberry 7290 by trying to load a new OS now it shows THE 507 ERROR i have found the right os and i still got the backup how do i load it on via usb thanx for your help adien
Ramaly B
Level 2:
  • Expert 250 Answers
  • Posted on Feb 28, 2011
Ramaly B
Expert
Level 2:
Answers
250
Questions
Helped
48448
Points
883
Hi, Download BlackBerry desktop manager. Install the DM and get the appropriate OS firmware file from the blackberry web site. install it and load it using the DM software. if the connectivity is ok, DM will be prompt to update the OS to the new one. Thanks, Ramaly
  • dirty09 Feb 28, 2011
    thanx i already had all the software n that dint no how to load it on the bb...
    all done now thanks : )
Error 507 please help
I'm sure it requires you to reinstall the phones firmware. Go to the following link to download the firmware:
http://www.blackberryforums.com/rim-software/1871-blackberryos-4-x-download-faq-upgrade-downloads.html
Code 507 with circle as soon as i switch it on wont let me do anything else
Error 507 appears when any subsequent attempts to perform an Application Load or upgrading the software
on the BlackBerry smartphone are unsuccessful
Solution :
1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2. Click on the Application Loader icon.
3. Click Update Software.
4. Type your BlackBerry smartphone password (if prompted) and click OK.
5. Select Options under the Device software options section.
6. Select the check boxes next to the names of the applications you want to install.
7. Click Settings, and remove the check mark from the check box for Back up device data automatically during the installation process.
8. Click OK.
9. Click Next > Finish.
10. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
If it shows the same error then please visit to the nearest Service centre.
1helpful
Reload error:507 curve 8900
well you have done great so far. Error 507 means that JL-CMDER has done its job and wiped all applications off your phone. So just do the next step by connecting it to your 4.7 Blackberry Desktop and select App Loader and install the OS and Applications on the phone. Please write again if you need more help
1helpful
I have a 507 error code
507 means no operating system found. You will need to reload the OS.  Device may require a clean wipe and re-install of the OS.
The 507 error means that the operating system is no longer on the device. Any data on the device is gone, too. You won't be able to retrieve it unless you have a backup.
You will need to reload the operating system on to the device. You will need the Desktop Manager program, along with the BlackBerry handheld device software.
You can find the Desktop Manager program here:http://na.blackberry.com/eng/services/de...
You can find the lastest BlackBerry handheld device software from your carrier's site. A list of them is here: http://na.blackberry.com/eng/support/dow...
And you can follow these instructions for upgrading your operating system:
http://crackberry.com/blackberry-101-how...
If I could be of further assistance, let me know. Otherwise, please rate this. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Blackberry 7290 device error:373 reset
Hi Anand
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
And please let me know .
7100 blackberry
you need to reinstall the OS!
Go to blackberry.com and download blackberry desktop manager!
and then you need your phones os which can be found at nextel.com
thanks
erik
4helpful
3answers
My blackberry 7290 showing "error 507"
good Days
I have problems whit my BlackBerry 7290. Wen starting it is showing "error 507". pls help me how unlock it.
post solution for me here..
thank you for help me
my regards
http://itot54joni-mobile.blogspot.com/2007/11/solve-blackberry-error-507-505.html
6helpful
5answers
Error code 507
dear,
i have the problem of 507 error on my blackberry model 7290. please be of help and tell me what to do about it.
thanks
ogbonna
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
