Click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Testimonial: "worked!"
If you haven't gone into your control panel and changed the preferences for your mouse, the mouse may not work.
Also, you may need to download a driver for the mouse. Which is software that allows the computer to recognize hardware, like a mouse and a keyboard.
http://www.targus.com/uk/support_downloads.asp
