A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Hello friend, we appreciate your post!
It appears you have a laundry center FEX831CS0 and that your dryer is not working. Can you provide me more specific details? Is your dryer not heating, not turning on, or not completing a cycle? For instance did you notice any strange functions or odd noises prior to this issue? With this information I can better address the issue at hand. Thank you - Matt
Hi L Martin - For this particular model FEX831CS0, the heating element part number is 131475320. The part may be purchase directly from the manufacturer or through a part distributor in your area.
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
