Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
Posted on Jul 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Neptune model # mah6500aww: makes banging noise and causes machine to move
When I star the cycle, it makes banging noise. The banging is so strong that it causes machine to move physically . I had to stop the cycle and then after some time the door is still locked with error code LO.
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
  • Posted on Sep 09, 2008
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607559
Points
3590
A loud banging sound in the pipes is usually caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The banging happens as the water hits the valve that prevents it from going any further. If the kinetic energy is great enough, it can actually cause a pipe to burst or explode at the end. If a valve is closed near the beginning or in the middle of a system, the water keeps flowing after that point, and it can actually create a vacuum. This vacuum can cause a pipe to implode if the stress is too great. Roaring type noises may be coming from a spin bearing. This bearing probably had the grease washed from it because of a tub seal leak.
Squeaking sounds in a new washer are usually caused by the new parts getting broken in, and will usually go away after several washes.
The sounds of water gurgling, slurping, or sloshing during a spin cycle are usually caused by the drain pump pushing the water out of the washer tub.
Too much water pressure can cause a whistling or squealing sound. Adjust the hot and cold intake water valves to relieve this sound.
Metallic clinking sounds during spin or agitation may be the result of drive train components meshing during speed changes or after a pause.
Swishing or swooshing type of sounds may be caused by water and suds trapped between the tub and basket during a spin cycle, and will usually clear up as the water is drained from the washer
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Maytag Neptune front load washer model MAH3000AW, load during spin cycle
    YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
    [email protected] OR 714-334-1998
    Smelly clothes after washing. We have one of the models that was recalled for the same problem. Maytag Neptune - MAH6500AWW
    I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
    1helpful
    2answers
    I have a Maytag Neptune MAH6500AWW mOdel. Less
    YES YOU CAN , CONTACT PLUMBERS SUPPLIRES WITH MODEL NUMBER OF MACHINE AND MAKE FOR BERINGS WHEN YOU HAVE THEM YOU CAN START, FIRST MAKE SURE POWER IS OF THEN LOCATE SKREWS IN THE MACHINE PANEL, REMOVE AND OPEN PANEL LOCATE BEARINGS AND REMOVE BRACKET HOLDING THEM IN AND REPLACE NEW ONES , IF YOU OPEN MACHINE AND HAVE A GOOD LOOK YOU WILL FEEL MORE CONFIDENT, GOOD LUCK.
    2answers
    Maytage MAH6500AWW Overloaded washer now leaks when filling
    since you can drain it
    take off the back and watch what happens when u turn it on
    i believe you make have a loose drain connection
    Sounds like something is knocking around in the back of the washer. On the spin cycle, the noise is very loud anyway, but it sounds like there is something banging around inside. The drum moves around...
    ok open the door
    make sure the thing is empty
    try to move the inner tub
    if you can shke it side to side anything but around
    you have a broken spinner support
    2answers
    Maytag neptune modle MAH6500AWW
    it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
    Top Maytag Washing Machines Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    ZJ Limited
    ZJ Limited
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
