Toshiba Vc-260 Remote Control Logo
A
Anonymous Posted on Feb 28, 2011
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote to the TV. How do I go about doing this.
Anonymous
Level 2:
Scholar:
  • Expert 71 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
71
Questions
0
Helped
20396
Points
152
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
I was wondering some codes for a RCA tv/ vcr combo
have a old rca television with a build in vcr. connectec a cable box remote works only for volume and channel but power button does not work, with remote was set and stop working call cable company and was told to contact rca to recieve codes for television
Sony SLV-N60 stopped playing suddenly
Sounds like you have a head-clog. You can purchase a VHS Head Cleaner at Radio Shack for $5.00. If that doesn't work repairing your VCR is not cost effective when you consider that you can purchase a new VHS/DVD combo deck for under $125.00
1helpful
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
Cant Power up/down. DVD player wont work
You can try leaving the television unpluged for a couple of days and see if letting the circuits completely discharge will let the television reset itself to normal operation. You can also call Toshiba customer support and ask them if this problem is common and if there is a simple solution. The customer service telephone number is 1-800-631-3811. Give them the model number of your television and they will help you. I hope this information help you with your problem.
1helpful
Forgot how to set remote up with tv
For the RCA RCR412S you might find that it doesn function like the manual says it should be functioning. In my case the Direct Entry method didn't work with my Sharp TV or my Panasonic VCR. I then had to figure out how the Automatic Search method worked because the manual was incorrect. Here is how to program the RCR412S using the Automatic Search method:
1) Turn on the component you want to control (TV, VCR, DVD)
2) Press and hold BOTH the component button on the remote and the On-Off button
3) The On-Off button remains lit. Now press Play (The On-Off button will blink)
4) If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
5) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
6) To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
You can download the manual here:
RCR412S Manual
Tv will not go on
On my GE Tv/VCR Combo I had a similar problem. Try holding down the Power button on the remote for at least 7 seconds. This disengages the parental controls. I found this solution on another website after my tv stopped working after my 20 month old played with the remote for a while. This solution was not in manual. I am assuming that he held down the power button for 7 seconds to engage the parental control. Hope this helps!
4helpful
Samsung tv/video panel lock
if you have a universal remote ( i just used the all for one 4 model )
1 ) press the vcr button. 2 ) hold the magic button down wait for 2 red flashes. 3 ) enter code 0240. 4 ) press the power button on the remote tv will turn itself off. this will get the panel lock off the tv.
i have just done this after 30 mins of trying to work out why the panel lock would not come off with trying the tv codes. you have to use the vcr codes. my tv is now working and my grandson can play his playstation again with no problems just had it working.
dated 13:07:2010 1800pm. hope this helps someone
2answers
TV remote is turing on VCR
Is it a original remote or a replacement universal remote? If it is the latter, then it looks like someone has accidently programmed it for the frequency which is compatible with the recieve frequency of the Remote sensor of your VCR or DVD player.
2answers
JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
Ifyou do not see the VCR/TV button switch on the front panel, then its a problem most likly with the firmware in the microprocessor. If you do see the VCR/TV indicator switching in or on the front panel display, most likly a defective RF modulator/switcher or RF antenna pack. You may still be able to get one from like MCM or tritronics or PTS corp can rebuild it for you. I have seen this type of break down many times with VCR's as we used to do hundreds of VCR repairs a day as we did factory service for several companies in the NY/NJ area. Good Luck Please do not forget to rate this thread.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
