My front load dryer pauses the last few minutes of drying time and then gives a code that looks like a C and a backwards C. Dryer does not seem to be drying like it used to.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load. 2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed. 3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Hello Kimwbarrym,
Maybe I can give you a few ideas on some things to check. As a general rule of thumb, to get maximum support here at Fixya, you should always include the brand and model of your appliance.. That helps us to tailor responses to your specific problem.. Anyway, regardless of dryer model, they all pretty much operate in the same basic manner and that is.. there is a heat source ( electric dryers use an heating element similar to an electric stove) A gas dryer is essentially the same but uses gas with an igniter to create a flame on a burner..) Outcome is the same.. Heat
Once heat is established, you need to move the clothes and the air thru the dryer compartment to optimize the drying efficiency. Both gas and electric models use a blower to move that heated air thru the compartment and out thru your vent system. If anything restricts air movement ( lint, blockage or any restriction in the blower or filter) your drying efficiency drops way down and dry times go way up. So. now you have the basics on how a drywer works.. Having said that... you need to check the basics first.. Make certain that you dryer exhaust system has NO restrictions to air flow.. you may have to detach vent line and check it for lint or anything in there.. If you have an electric dryer.. you can turn it on for a minute or two with the vent linbe disconnected to see if you are getting robust air movement.. If you aren't , then your problem is internal to the dryer, If you are.. you may have an exhaust duct restriction. Although not recommended, you can do the same for a gas dryer in a well ventilated area just to check the flow intensity.. But.. only for a short time since the gas burn byproduct is unhealthy for you to breath. I forgot to mention that the drum inside the dryuer should be moving the clothes during all this.. that acellerates the dry cycle too. Lastly, you need to make sure you are getting heat.. You can start a dry cycle with the dryer empty to see how warm it gets.. It should get fairly warm. Not sure I helped you but you now have a few things you can try. If you continue to have problems with this, feel free to contact me via this forum but please include the model number of your LG appliance..
Regards,
Rick
Try checking the back, there is a plastic tub that is connected to the drying system and it can get clogged with lint etc. It will also cause the unit to give you longer drying times. It is a poor design. You can also pop off the lid to get a better look but make sure you unplug the unit.
Sgt 48
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
