Washing Machines Logo
Posted on Feb 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer is out of balance. it just leans to the left side and makes loud noise like metal on metal.
Anonymous
Level 3:
  • Master 1,940 Answers
  • Posted on Feb 27, 2011
Anonymous
Master
Level 3:
Answers
1940
Questions
0
Helped
954094
Points
5951
It sounds like your drum support, and/or balance mechanism inside the washing machine has broken. You will need to open your Washing machine and inspect the Drum Support, and the balance mechanism. Hook it back up or replace it if it is broken.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Grinding noises
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Why is my fridgidaire top loading washer so loud?
You didn't say when it was making the loud noise. During the wash cycle or spin cycle? An unbalanced washer will make a loud racket, too many clothes or actually not enough will make the basket bang around in there. If it has a center agitator, make sure it is tightened down. The screw is under the center Fabric Softener cup. That's the easy stuff to check. Now on mine, when you take the front panel off, I noticed that the hooks and springs that hold the basket up & in place and help keep it balanced, had actually over time had worn the round holes in the metal construction of the machine to oblong holes. Not much you can do about that. If the noise is coming from the motor, & you can't find a used cheap one, it would be more cost efficient to just use as long as you can and buy another machine. A loud noise could also be caused by a bad pulley. Hope this helps.
Loud noise on spin cycle
By the way my advice is free cuz God is good!
How do I remove the agitator for my machine ? It is loose and spins fine, but makes a clanging noise when agitating counterclockwise during the wash cycle. It seems like I just need to tighten it down...
Anyone with loud scraping/clanging- we had that problem and saw that the large wheel the belt goes around is only an inch above the metal bottom.When we moved the washer with a 2wheeler it pushed the bottom up into the metal wheel. The racket it made was horrible. It left metal shavings ,too. You'll need to pull the bottom of the washer back out.Pull fromt panal off with putty knife.You'll need to lean or lay washer to one side.Put a pillow or cushion inside between the tub and housing side you'll be leaning towards. What I did was drill two little holes-one near the back center and one near the front center. I took a long piece of heavy string,put one end in one hole and the other end in the other hole-outside to inside.Tie the ends around each end of a 1x2,18inch board .Get the board to the back without damaging stuff inbetween-pulling on your back string for help. Make sure the board is against the bottom, get to where you can now pull your string 'handle' w/both hands,yanking and popping the bottom back out.Our washer now works beautifully and quietly.
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
4helpful
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
2answers
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Noise in my washer while agitating
Maytag have had some problems with the bases of the unit. If you open the lid and it is leaning to the right this is the problem. You have to change the base of the unit and the springs that come with it. This is the only correct fix, but is a costly one.
Sgt 48
Top Washing Machines Experts
john h
