Hi, I'm sorry to tell you that if the glass of your Swatch watch is broken it is quite impossible to repair it, it's a well known fact about those cool, not so expensive watches.
You may need to open it from back to get the inside of the dial. Then use a **DRY CLOTH** to gently wipe inside of the glass.
To play safe take help of a watch technician.
Thank you for contacting Fixya,<br />
I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br />
You can contact Swatch at:<br />
<a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
hELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok?
best regards mike
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch. The main dial has a minute hand and an hour hand. The big second hand on the main dial is not for the main time of the watch. It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch.
Top Button: Start/Stop
Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons. Also, pull the stem out further to the 2nd position and push the buttons.
